20 Most Recent Sony KLV-S32A10 32 in. HD-Ready LCD Television Questions & Answers
Go to settings and use anything other than wide option. Setting there - just look for it.
Sony KLV-S32A10... • Answered on Feb 21, 2016
0261,0266,0200. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
Sony KLV-S32A10... • Answered on Jul 22, 2014
Hello
Programmable code number for DVD/VCR [Sony] is _ 601 (Sony Dream System)
Programmable code for SAT/CABLE is _ 801 (Sony Satellite Receiver)
Above stated both codes are common for [SONY KLV-S19A10 _ KLV-S26A10 - KLV-S23A10 AND KLV-S32A10 compactable]. OK.
Sony KLV-S32A10... • Answered on Jul 20, 2014
Some TV's can be connected to the internet and are then able to get software updates from the manufacturer. Look into that as a possibility.
Sony KLV-S32A10... • Answered on Dec 21, 2013
Have a look here I have the same problem and have been looking for 3 days...I hope this helps as I have tried the service manual and the part number is...1-805-870-21...with no luck...http://www.invertercentral.com/qrySpecSheet.asp?page=srlp&name=LTA320W2-L02&number=LTA320W2-L02&title=Toshiba&Country=Australia
Sony KLV-S32A10... • Answered on Sep 13, 2013
Count the number of blinks occur at one time switch ON. These are fault indications, called blinking codes. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help. Blinking codes to Sony TVs are described in detail.
Sony KLV-S32A10... • Answered on Apr 04, 2013
038,028,057,014 are the common setup codes for Sony television. If you want to get more details about setup codes and setup proceedings to different other brand remote controls, check this link. Look for codes to Sony. In most of the remote controls will have setup codes for Sony. Before selecting a remote control, check the digit number of code that your Sony Tv accepts. some of them accecpt 3-digits codes, others accept 4 digit, 5 digit and so on. You can get details to all by this site. Search it patiently.
Sony KLV-S32A10... • Answered on Feb 25, 2013
The Roku is the problem, not the TV. You need to go to the Roku site and request download information to synch the Roku to an HDMI input.
Sony KLV-S32A10... • Answered on Jan 13, 2013
You are discussing about the service mode setup procedure to this TV, I assumes. Check this to know more. Your TV model's service mode entry and other details are described in detail there.
Sony KLV-S32A10... • Answered on Jan 07, 2013
I hope that you have gotten this resolved, but if you have not, or if you have the problem again in the future, here are some simple steps for you!
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
500
837
Becki Barned
DISH Network Customer Service
[email protected]
Sony KLV-S32A10... • Answered on Aug 11, 2011
You need to change out the caps on the video processing board,caps (smd) type have gone bad ,must replace the caps by exp. or qualified tech,must be able to unsolder and solder components ,make sure to clean board with some denatured alcohol ,board gets saturated by electrolyte that leaks out of the caps,common problem ,happens in all electronics,that or take it to the shop,caps look like little silver round cans
Sony KLV-S32A10... • Answered on Feb 04, 2011
High definition ready is different to Full High defintion for the simple reason the software is different to prove play a HD play station game on both and you will immediately see the difference in picture quality however the difference is not so significant on your normal satellite HD channels depending on the resolution the TV can produce
Sony KLV-S32A10... • Answered on Nov 23, 2010
Sony KLV-S32A10 32 in. HD-Ready LCD Television Logo
69 questions posted
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
S Sony
  • S Sony
Most Popular Question
tv doesn 39 t recognize hdmi roku
  • Televison & Video
