Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
Find the pink Clear button on the Control Panel of the WorkCentre.
Find the button below the word Auto.
Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto]
NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
Press the green [Start] button.
Press the pink [Clear] button two times.
The WorkCentre should now warm up and come to ready.
If the above steps do not clear the error code, repeat steps 3 to 6 a second time
You cleaning blade for the drum may be needing replacement, mite have some harden toner on the cleaning blade alowing toner to run around the bad/hard toner leaving streaks
There is a small sensor on the fuser that most likely has become disloged. It requires a lot of disassembly to get to.
But an E2 code is that sensor not being cleared off. It pops out of the frame sometimes during paper removal.
