When on button is pressed, green light come on then caanges to yellow.
SOURCE: boot up problem
It is possibly the RAM it may have ceased. Look at it underneath held in by two screws. Take it out and examine it then put it back. The motherboard seems ok because you said the lights are lighting up. Sometimes the ram can stop even the bios and nothing can boot up.
SOURCE: hp compaq nx6310 wont turn on. When pressing power
it will either be the batery is no good, or adapter ot the port on your laptop
SOURCE: Battery Wont Charge
Hi there as per your information there is a chance of battery damaged. So i suggest you use your battery in others laotop for confirmation. If your found the same problem then buy a new battery . Thanks & waiting for your feedback.
Try this:
Drain the static on the computer by removing the battery and the power adapter. then press the power button for 1 minute and release. Then plugged the battery back in and turned on the computer, if the computer won't come on plugged the Adapter back to the computer and try turning it on.
If problem persist it is possible that the battery already busted and you need a replacement.
Hope it would help.
SOURCE: my hp compaq nc8340 won't turn on
Need a new battery, I believe. Just find hp compaq nc8340 battery replacement.
