20 Most Recent HP Compaq nc6320 Notebook Questions & Answers
> Open Control Panel
> Sound Properties
> Speaker Properties
> Enhancements
Loudness Equalization : on
Equalizer: Choose one (Jazz seems to be loudest setting but sounds of hallway effect so I use powerful for clarity.)
This has more than doubled the level of volume on my acer 5570.
- verc
HP Compaq nc6320... | Answered on Dec 09, 2019
FORGOT PASSWORD hDD BAY HP530 PASSWORD Unlocked and try again
HP Compaq nc6320... | Answered on May 30, 2019
George Mangwiro wants answers to this question
George why hyjack 2011 posts. lazy?
why not ask at HP.com
HP owns Compaq for over decade now, and supports it some what (limited)
no screen photos of this error show by anyone here, so what you see, is anyones wonder. blind we are .
HP designed it, built it and sold it and supports it, why ask fixyah.
we dont have access to back doors, or magic security flash resets. all can do is POINT. here is me pointing to the correct place.
HP.com
https://h30434.www3.hp.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&q=+Compaq+nc6320+password
join and ask them, magic can happen toss a coin
if you posted a screen with errors we can tell you why and how hard it is, but that is all.
nobody ever posts the screens of error s here, so goes sideways./
HP Compaq nc6320... | Answered on Dec 11, 2018
that is new mobo time, the charge or any reg chips bad.,
is the size of 1/8 of a baby's pinky finger nail
and has solder ball bottom SMD , tech.
you will never replace it and make it work again'
at home.
id give that a 1 to 1000 shot. success.
ever work SMD before?
new mOBO time, ask any tech, same answer.
have you removed all mobo modules first, to prove this case.?
any module can short, remove them all.
mine has 7 to pull.
http://www.pcdied.com/765-quad-core.jpg
HP Compaq nc6320... | Answered on Nov 13, 2017
finger print sensor
HP Compaq nc6320... | Answered on Jul 14, 2016
Hi FRND,
This is the unrecognized file of windows this is the VIRUS which is affected to you PC system...
You have to install the Good Antivirus on your system... eg. Norton, Macfee, and Nod32 I have the NOD 32 antivirus on my system if you needed below mention is the link…
http://rapidshare.com/files/75274189/ESET.NOD32.Antivirus.Business.Edition.v3.0.566.CRACKED-CU_Uploaded_By_Afaz_.rar
Best Luck…
HP Compaq nc6320... | Answered on Mar 24, 2015
Download the HP Format Tool and install it. Get your boot disk or the downloadable files and copy/extract them to a folder on your HD. Make sure anything on your USB Drive is backed up because we are going to format it...
Open the HP Format Tool
Start/Programs/Hewlett-Packard Company/HP USB Disk Storage Format Tool
It should automatically select your USB Drive.
Select FAT or FAT32 Under File System.
Select Create a DOS startup disk
Select using DOS system files located at and point to the folder containing the boot disk files.
Then click Start
Or you can download Win to flash ,follow the bellow link for details,
For Windows xp
http://www.intowindows.com/bootable-usb/
Or
http://www.makeuseof.com/tag/how-to-create-a-bootable-usb-drive-from-your-windows-cd/
For vista
http://downloadsquad.switched.com/2009/08/27/make-a-bootable-usb-installer-for-windows-xp-vista-7-with-wint/
Hope this helps.
Let me know if you need more information
Thanks.
HP Compaq nc6320... | Answered on Mar 16, 2015
i have a Compaq nc6320 when i plug in the power cord the electricity led doesn't want to turn on i have changed the cords and the adapters and i doesn't power on or even charge the battery, did any one have an idea what to do in this problem?
HP Compaq nc6320... | Answered on Oct 21, 2014
Make sure that the internal fan is cycling or working. if this fan is not running, it will allow the laptop to reach unsafe temperatures that will damage the circuitry over time.
Replace the cooling fans if they are not functioning.
HP Compaq nc6320... | Answered on Jul 12, 2014
Go to control panel, click Pen and Touch to enable or disable the Pen and Touch.
HP Compaq nc6320... | Answered on Jun 19, 2014
Go into CMOS config, and see if the usb device can be added to the sequence, save cmos, cold start with usb in machine.
HP Compaq nc6320... | Answered on Jun 01, 2014
Most PCs will not boot usb, unless the CMOS setup configure supports that device as a boot choice on cold start. F10 or does allow whatever key strokes needed before windows logo, will get you into CMOS config. Then look for boot, sequence and see if the usb is an option, if not, no hope for usb boot.
If CMOS config does allow usb boot AND your usb device has been set up to be a boot device,(and you saved the cmos changes) with the proper files...
shut dow, put in usb and cold start.... save
For any laptops, if it shows a blank screen, all persons including you can do some 'first aids'.
First Aid A:
1) Remove the battery and AC adapter.
2) Press and hold on the power button for one minute and then release.
3) Connect the AC adaptor and switch on the system.
If it doesn't solve the problem, try 'First Aid B'.
First Aid B:
2) Locate the RAM module. It is usually at the back side of the system under a removable lid.There are one or two screws for it. Remove the screw and take the lid. Then you can see the module.
3) Pull the arms of the holder of the RAM gently outward and take the RAM out.
3) Insert it back by holding it at an angle of 45 degree from the motherboard surface.
4) Connect the AC adapter.
5) Switch on the system.
If it doesn't solve the problem, try 'First Aid C'.
First Aid C:
1) Replace the RAM module with a known good one as expained in 'first Aid B'.
2) Swich on the system.
3) If it fails to vew the display, connect an external display.
4) Turn on the external display by pressing the Fn and F8/LCD/CRT keys.
If all these things are failed, then it is a motherboard problem or due to a currepeted BIOS. Contact a service personel.
If this document is helpful or not to you anyway make a comment.
If you are a laptop technician I can further help you contact me.
HP Compaq nc6320... | Answered on May 29, 2014
Does the computer complete a POST test? In other words do you see the HP/Compaq logo when you first power on the computer? If not then you have a hardware problem, most probable the motherboard. If you see it, then you can try to restore the operating system either with a recovery disc provided by HP or possible a recovery partition. Note the menu options when you power on the computer F10 or F11 is typically to start the recovery process if available.
HP Compaq nc6320... | Answered on May 09, 2014
Hi Adel,
I am afraid there is no way still to retrieve BIOS password but you may want to contact HP Support to check if they have ways to check that for you. Usually for the case you have it is replace MOBO already. Please check the number on the link below base on your location.
Contact HP Phone Assist HP Official Site
HP Compaq nc6320... | Answered on Apr 26, 2014
1- check if the volume level is high
2- check if the sound is out from the jack of headphone if so :
1- replace your in speakers
2- use usb speakers
HP Compaq nc6320... | Answered on Apr 09, 2014
HP Compaq nc6320 Notebook Logo
237 questions posted
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
crack bios password compaq nc6320 please
  • Computers & Internet
