20 Most Recent HP Compaq 6735s Notebook Questions & Answers
Either the Dc in cable (cable from adapter jack) is faulty or the issue is with battery/mothorboard.
To confirm check with other battery and if it is charging the the issue with battery circuit.
Thanks
HP Compaq 6735s... | Answered on Dec 11, 2018
we are not HP , but here they are, ask HP.
if you wanted to fix something this old where would you get good parts, not HP, its too load, ebay has lots of bad parts, guess?
https://h30434.www3.hp.com/
HP Compaq 6735s... | Answered on Dec 11, 2017
No OS stated, XP? VISTA,
'ok its HP but old but not too old, 2008\
in the magic year of 2006 HP added the F11 key to the old Compaq line. (hp bought)
so if the PC is still 100% HP and the hard drive not slammed with alien MS disks, from MS. then the recover partition works
so power on F11 hammer f11 fast, and bingo F11 recovery runs. pick fix startup files repair
fails still then reload the whole OS now back to DAY1.
all HP do this 2006 to now.
all do unless is bad or was bad long ago HDD bad, HDD SLAMMED.
my guess you ran DBAN, and why not fess up and say the full name of the product, (app) or there web site you got it URL
then we know what you did,.
DBAN erases it all the HDD is just empty space
and F11 is gone gone for ever more.
then you can do this.
see the 6 ways here, #1 is now erased leaving 5
#2 is gone at HP this old.
4 left.
#3 is your best bet.
http://www.pcdied.com/HP-OS-GET.html
HP Compaq 6735s... | Answered on Nov 18, 2017
Check first if you didnt dimmed the light to total black from keyboard. If thats not fixing is a mostly sure video chip fail.
HP Compaq 6735s... | Answered on Nov 03, 2017
why not post what PC does,with no battery IN IT and the NEW power pack is used? this be first first.....!!
if that fails wrong pack.
only 3 possible reasons,
1: new battery is bad, (stuff happens and if china cloned x10 that)
2: wrong pack (i bet this is it, and hope so)
3; PC chips blown out (there are 2, a power reg, and charger reg)
so how do we avoid guessing?
well ,first is does it run with no battery and not stated by you yet.
the wall pack has to be 2 things to BE correct.
1: 19vdc, is it?
2: and watts, my HP elite book as 3 performances opens when new. (actually 5x3 permutations in fact)
A: faster CPU, $$$ 5 choices, the i7 is top and sucks power like mad.
B: one of 3 GPU cards inside, one sucks power like mad.
Mine has both, and needs the HP 100watt pack or WILL FAIL.
Mine is also the most fast of the model line
speed sucks power, in computers.
so learn what your HP needs. first.?
if you bought it new, then pack is correct, and states on the side of
is 19vdc and watts. so read that now, and match that.!
i bet you only guessed ,right?
if you did not buy the LT new, then you get to ask HP what you have.
ever heard of HP.com?
go there and ask,? magic happens, FACTS ! endless....
and HP has records based on Serial numbers. on yours.
this serial tells them what you got DAY 1. (we are NOT HP)
Just like a car, ordering the huge V8 sucks more fuel.
see?
I cant see under your hood so cant tell you what is there.
as you can see computers are not a toaster or desk lamp.
ask here, and JOIN.
HP Compaq 6735s... | Answered on Jun 15, 2017
bad battery,
you do know that the main batteries are "love to fail"
right,
just about all batteries do that in everything,
even the coin cell,inside can fail in 5years flat.
if power pack is 19vdc with volt meter, good !
the battery is next, yes it runs pc but can be bad.
a bad battery can still have power but overloads the charger chip
it really is an analog world. (reality)
if savvy , always keep a spare battery for moments like this.
HP Compaq 6735s... | Answered on Apr 12, 2017
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A noisy fan is most likely faulty.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
HP Compaq 6735s... | Answered on Jan 05, 2015
You won't be able to do it yourself. You'll have to contact an authorized HP support center.
There used to be "easy" ways but now the password is stored on a chip on the motherboard.
HP Compaq 6735s... | Answered on Dec 13, 2014
A) If you installed a different, unsupported operating system recently, USB ports might not work properly. B) USB ports might be burned due to an arc. If so; they need to be replaced with new ones.
HP Compaq 6735s... | Answered on Nov 20, 2014
the bottom line using control alt delete will bring up a menu to troubleshoot. be careful.
HP Compaq 6735s... | Answered on Oct 25, 2014
well you will have to go to your bios settings first and disable you touch within the bios. plz let me no if you need help with the touch pad
or bois
Lap tops require special in/out plugs for connection to tv.Then keyboards keys to select the display function. Check your manual for this info
HP Compaq 6735s... | Answered on Apr 14, 2014
If you close the computer down in thew usual way,it will re boot in normal mode. If it still has errors, it will return to safe mode until the error has been cleared.
HP Compaq 6735s... | Answered on Mar 19, 2014
If you go back into setting, click on it again and that should put it back.
HP Compaq 6735s... | Answered on Feb 09, 2014
Test with an external display. If nothing, there may be a GPU issue.
HP Compaq 6735s... | Answered on Jan 31, 2014
HP Compaq 6735s Notebook Logo
240 questions posted
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
non stystem disk or disk error replace
  • Computers & Internet
