Whirlpool WTW6400SW Cabrio Washer Logo
Anonymous Posted on Mar 10, 2012
Whirlpool Cabrio Lid
Lid has clear top. Plastic frame has cracked on back right corner and door lock won't engage. Can I disable the door lock sensor until I get a new lid and what's a good source for the lid. Where can I find the exploded drawing to replace the lid.
Owen Barnes
Level 3:
Top Expert:
  • Master 867 Answers
  • Posted on Mar 11, 2012
Owen Barnes
Master
Level 3:
Top Expert:
Answers
867
Questions
0
Helped
399156
Points
2534
The lock cannot be disabled, The lid removes easily and is also simple to replace.
Depending on where in the world you are depends on where you will get a lid, If you do a google search in your area for whirlpool spares you will get some results.
  • Anonymous Dec 11, 2012
    Here's the problem...this plastic hinged top will just keep cracking. I purchased this same washer in Nove 2011...three months later the top hinge on the right side cracked. The local vendor replaced it for free. Today, I see that the other side has cracked and the vendor tells me the warranty has expired. I can get this replaced, but it is just going to keep happening.
  • Anonymous Dec 12, 2012
    It seems like everyone having the same issue and whirl pool will not take ownership for it.
5 Related Answers
Anonymous
  • 1937 Answers
  • Posted on Nov 10, 2009
SOURCE: Installing a whirlpool cabrio washer lid switch.
See the following Whirlpool Service Manual for the Cabrio.
This should help.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Anonymous
  • 572 Answers
  • Posted on Feb 06, 2010
SOURCE: The lid will not lock on my Whirlpool Cabrio
id change the door switch
Anonymous
  • 98 Answers
  • Posted on Jul 31, 2009
SOURCE: the lid to my cabrio washer will not open
Slowly turn the dial to the end of the next cycle, without actually turning on the machine....if you hear the lock open, success!!
Anonymous
  • Posted on Jul 09, 2010
SOURCE: how to fool the whirlpool cabrio 7340 lid switch?
PULL THE WHOLE TOP UP THERE ARE TWO CLIPS THAT HOLD IT TO THE FRAME IN FRONT YOU CAN POP IT UP WITH A FLAT HEAD SCREW DRIVER TO KEEY THE LID FROM CRASHING DOWN ON U TAPE THE LID TO THE FRAME IT SITS ON
Anonymous
  • 1382 Answers
  • Posted on Jul 28, 2010
SOURCE: Will start the wash cycle and DL come on and light
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Cabrio wtw7800xl2 Lid frame beaks! Want TO Replace
You can try going to repair clinic at repairclinic.com and probably get the lid along with video help.
1helpful
I have a Whirlpool Cbrio top load washer. it won't start it's cycle. Once it senses the load, the lock lid light flashes and it does nothing. can this be fixed?
I would say that the lock has failed. Either the lock itself or maybe the pin or latch that fits into it when you close the door may have cracked / broken. If the machine thinks the door / lid is still open, it wont let you start it.
3helpful
Lid lock won't release on Cabrio washer
hey there have you tryed un plugging it the pluggin it back in
2answers
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
3helpful
2answers
Washer displays message of dl when trying to start washer
Hello bculwil Welcome
“dL” (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid
keeping it from closing. Press PAUSE/CANCEL once to clear
the code.
Or the lid lock sensor is faulty and needs to be diagnosed and replaced
Please remember to leave a solved rating before signing out.
Thank You Huum
My Whirlpool Cabrio Washer keeps giving me the DL (Door unlocked code) even though I can look under the lid and see the latch extend out. I think the plastic to the glass lid has warped, keeping the...
try the lid switch/lock first ..press clips under edge each corner raise top 2 screws hole switch in place remove 3 screws along back of control panel lift console up and forward switch plugs into control bd on left side
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
