20 Most Recent Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Questions & Answers
It sounds like your solenoid coil(s) might be no good. Easy fix and not very expensive.
Whirlpool Cabrio... | Answered on Jan 13, 2018
Did you clean the exhaust duct from end to end?
Some of these have a two-belt system where the second belt turns a fan blade that resides in a plastic housing beneath the drum... the pulley will come loose and fall off sometimes which can cause this error... Help Me Find My Model Number RepairClinic com
Whirlpool Cabrio... | Answered on Oct 10, 2016
Is the dryer vent blocked with lint? If there is a restriction in air flow in the vent system, the dryer will stop. Make sure the vent path is completely clean even in the wall where the vent hose connects.
Whirlpool Cabrio... | Answered on Oct 08, 2016
Revolt! If you own a Kenmore Oasis (built by Whirlpool) or Whirlpool Cabrio washer, and you are getting the "F1" error code...or similar codes, and nothing you do fixes the problem...REVOLT!
Three options: Join the class action lawsuit, sign the petition, or be a just another chump consumer. All info is below. I for one, have HAD IT with a 1000.00 washer that breaks after one year.
Here is the class action law suit info. I got
this email a couple of days ago. Remember, these Kenmore Washers (built by Whirlpool) are basically the same machine as the Whirlpool Cabrio:
"Thank you for your interest in pursuing a lawsuit against Sears relating to the Kenmore HE4t and HE3t Washing Machines. This lawsuit is currently being handled by the law firm of Seeger Weiss, LLP. Sheller, P.C. is co-counsel on the case. Your inquiry submission will be forwarded to Seeger Weiss, and you will be contacted by a Seeger Weiss representative shortly."
Read more: http://forum.appliancepartspros.com/washer-repair/10337-whirlpool-f1-code.html#ixzz1qRPaiZXt
http://www.on-timeappliance.com/washingmachinerepair.html
Whirlpool Cabrio... | Answered on Oct 11, 2015
EITHER BAD FELT GLIDES, ROLLERS OR DRUM BEARINGS
Whirlpool Cabrio... | Answered on May 07, 2015
It is not unusual for new appliances, espicially high heat ones like a dryer to smell hot. Also if this is your first gas appliance it might smell different than your old dryer if it was electric. Keep an eye on it when using it to see if you see any smoke. Also check your venting to make sure it is all clear with no blockage.
Whirlpool Cabrio... | Answered on Jan 11, 2015
its not a rust problem sounds more like one of the hoses or tubing came loose or has a hole?
Whirlpool Cabrio... | Answered on Dec 05, 2014
enough to vent out of the building ,
Whirlpool Cabrio... | Answered on Sep 08, 2014
You can google whirlpool cabrio dryer codes and find the code that you are looking for. I just looked it means your dryer is not heating.
http://dryernotheating.net/whirlpool-cabrio-dryer-f1-error-code/
Whirlpool Cabrio... | Answered on Aug 02, 2014
Replace the door switch? The following website has helped me...
http://www.partselect.com/Repair/Dryer/Will-Not-Start/
Whirlpool Cabrio... | Answered on May 25, 2014
I pulled the circuit board out of this part and used a piece of duct tape to secure the broken plastic keeper that aligns the plastic button actuator with the switch on the circuit board. I've searched for this part too and can't find it. You can buy the whole control panel for $150. The duct tape might last a couple days or a couple years. As long as the plastic holder doesn't become dislodged it should last a long time. Another reason why I hate plastic parts - they break. Good luck in finding this part - if you ever do post your solution here.
Whirlpool Cabrio... | Answered on May 20, 2014
Does your drum light cut on and off with the opening and closing of the door
Whirlpool Cabrio... | Answered on Apr 27, 2014
Yes probably need new felt on back end of drum. Very common.
Whirlpool Cabrio... | Answered on Apr 14, 2014
don't forget the exhaust tube coming from the back of the dryer and leaving the building. those can get pretty restricted with lint. Another place to look is inside the cabinet for lint. Getting these cleaned regularly can prevent a fire.
Whirlpool Cabrio... | Answered on Feb 16, 2014
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Logo
132 questions posted
Top Whirlpool Dryers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
jdthefixer
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Dryers
  • Whirlpool Dryers
Most Popular Question
sound steel when tub running
  • Dryers
