HP Vs17 17" LCD Flat Panel Monitor Logo
Anonymous Posted on Mar 09, 2012
Random pixels wrong color - HP Vs17 17" LCD Flat Panel Monitor
Anonymous
Level 3:
  • HP Master 6,771 Answers
  • Posted on Mar 10, 2012
Anonymous
HP Master
Level 3:
Answers
6771
Questions
0
Helped
1779398
Points
21413
This not good, the problem is in the video processing board that is part of the LCD panel, not cost effective for repair, cheaper to replace.
Samsung tv pixel problems
if nothing has happen you tv just change the cables and see if not work send your tv to manufacture or retailer if there is a warranty hope that it will help you
TV showing color pixels but no picture and no sound
Well at least you didn't pay for the TV. Your panel is defective. Cheaper to buy a TV than to fix.
Pixels going bad, what can I do?
you have a stuck sub pixel. There are some videos or DVD's that will flash random color patterns that "supposedly" will help fix stuck sub pixels. I've read where someone suggested taking a sharp pencil, plaving a soft tissue over the pencil point, and softly poke the sub pixel to get it unstick. I've never tried these so don't know if they will work for you.
My sonny vaio's display has garbage on it (it's like there's some pixels out of colors and the resolution problems) what may be the cause of it? BTW vgn-fz31m
i think i have the same problem with my Toshiba Satellite p100 i am having a heap of pixels with the wrong color on my screen and the thing is that the number of pixels position and color depends on the image on the screen any help
1helpful
I have random pixel problems all across my DLP
Hi,its sounds like an
issue with the dmd.This is
how the dmd works:
http://electronics.howstuff
works.com/dlp1.htm
Basically the dmd is a chip
that carries 2 million
pixels that create the
image and colors .When its
bad it will cause
pixilation,color
discoloration or
stripes.God bless you!
2answers
RGB Pixels
sounds like the graffix card maybe over heating you will probably get e74 error and have to send it in same thing just happened to me.
Lcd tv with wrong color on one pixel
LCD screens occasionally have what are called "Stuck pixels". There is a tutorial in wikihow which might help you out here:
http://www.fixya.com/manuals/w153177-fix_stuck_pixel_lcd_monitor
Try that and see if it helps. Stuck pixels are actually a slighty common problem.
Sharp Actius AL27 pixel problems
From what you described, it seems as though your LCD panel is going bad or the inverter board is bad. Does it change colors if you were to reposition (tilt) the LCD back and forth in either direction?
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
