Monitor take 30 minutes to come on. When I hit menu button the code above appeared and stay on the screen all day
SOURCE: my sansung monitor bring a lock and unlock menu on the screen
Befor replacing the Control ic please check the micro switches those could also be faulty.
SOURCE: Menu screen keeps appearing
Why is it Dangerous to open the monitor? I almost did it this morning! because I guessed it WAS a mechanical problem.
SOURCE: Lock/unlock symbol appears in the middle of the screen
hold the menu button between 10 and 20 seconds until the lock changes to unlock
SOURCE: I HAVE SAMTROM MONITOR OF 56V IF I SWITCH ON
get it repair or it would be wrost...because in this fault 5 volt regulator i.e 7805 gets malfunctioned and it may led to switch off your monitor.
Channel guard and V-Chip settings are protected by a four-digit lock code. Your TV comes
pre-set with a lock code of "0000". You may change the code to any four-digit number you
wish. To change the lock code, follow the steps below.
Press the MENU button
Press [UP/Down] button to SET LOCK CODE.
Press [=> / <=] buttons to operate [lock icon appears]
Press ZERO to acess the lock code. The first digit will be highligted.
Press [ => / <=] button to select the number.
Press [Up/Down] button to move the next digit and continue to follow these directions for all the four digits.
Press OK button to finish.
Press the menu button when finished
DO THIS AFTER UNPLUG THE TV FROM AC MAINS WALL SOCKET, AND LEAVE IT FOR ABOUT 30 MINUTES OR SO, REPLUG IT TO ac MAINS, AND DO ALL THE ABOVE SAID PROCEEDINGS. THIS PROCESS WILL ERASE ALL THE V-VHIP CODES, IF SET, AND WILL ALLOW YOU TO SET AN OTHER OF YOUR OWN. The default V-Chip code is [0000]. Ok.
