2004 Chevrolet TrailBlazer Logo
Steven Lege Posted on Feb 28, 2012
07 trailblazer driver window and passenger window stoppped working..The door locks don't work and the remote mirrors don't work..I bought new switches for both doors and now the drivers door w
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 28, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1012
Points
Check for for broken wires where door hinges are at. pull back rubber boot and check them.
5 Related Answers
Anonymous
  • 1986 Answers
  • Posted on Sep 29, 2009
SOURCE: Need to replace passenger side mirror of 2004 Chevy Malibu max
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Then you can access the bolts that secure the mirror onto the door
Anonymous
  • 1986 Answers
  • Posted on Sep 21, 2009
SOURCE: Im trying to replace the passenger mirror, need to
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Once the panel is off, you will see two or three bolts securing the mirror assembly onto the door
Testimonial: "Thank you so much. I just wasnt sure were the bolts were inorder to get off. That helped me a lot thanks!!! "
Anonymous
  • Posted on Jan 08, 2009
SOURCE: passenger side mirror
If you need to replace the entire mirror - it's a little involved. First you need to take the upper extension panel off from behind the mirror (black triangle) - just pull it of starting at the top. It will snap back on later. Next - remove the different screws holding the door panel in place (not the ones behind the mirror yet!) One is under the handle (pull it out and pull out the filler panel - small plastic thing that has a hole to pry it out). Then take off the rear red light - also pops off - and remove that screw. Finally - pick up the rubber filler where your fingers pull the door shut and remove these torx bolts.
Now is the tricky part. Snapp off the entire interior panel. It will pop off - but very difficult. It will sound like it is breaking! Start at the outer bottom corner - and use a door panel remover tool - check Amazon or E-bay - to keep from breaking things. Pull it out from all around the bottom and sides and then lift it up over the door lock. It good to have a friend help here. The panel will still be held on by a cable - that is your door release - leave it alone and let the panel hang by it (or better, put a box under it to rest on).
Now...remove the three bolts holding the mirror on - have a friend help hold the mirror while you do this or it will scratch your new car! Since the inner panel is off - you can also disonnect the mirror plus and remove it. It sounds silly - but the only reason to remove the door panel is to unplug it!
Get you new mirror and reverse the steps.
If you are just replacing the glass (non-heated) - get a replacement from the dealer. Adjust the mirror all the way to the inside and reach behind and pop it off. CAREFUL - put tape over the entire glass as it will likely break even more! Remove your connectors if heated - and replace (and reconnect) with your new glass. It just pops back on!
Replacing glass is easy - just be careful of cheap imitations on e-abay). And never use cheap flat glass on the passenger side! The DOT has special requirements for mirror glass - buy it from gmpartsdirect.com or your local dealer.
kb
Anonymous
  • 59 Answers
  • Posted on Feb 23, 2009
SOURCE: How to replace side mirror glass and frame ? 2002 Chevy astro van
It should snap out and the new one snap in. Most auto glass companies can order just replacement glass from burco mirror. http://brokencarmirror.com/replacement/mirrors/
Anonymous
  • 72 Answers
  • Posted on Apr 08, 2010
SOURCE: How to replace passenger side mirror. Glass is
You can usually just replace the mirror, any commercial auto-glass store has the glass you need. sometimes it is necessary to replace the mirror and its backing (a plastic frame which snaps into the adjustable motor) you don't need to replace the whole mirror unless the housing is broken.
Please rate this answer. Thank you.
2answers
2007 chevy silverado power window dome light and power mirror passenger side front
Beings as everything that stopped working is on the passenger side, I'd think some wiring got disconnected or broken.
2answers
I have a 2000 Jeep Grand Cherokee...the electric windows quit working...don't have power to either driver or passenger windows, only power to passenger door lock, what else do I need to check?
For Doors not getting open with remote or key problem,there are help links provided below.Click the link below to go through its procedure and troubleshoot the problem:----
drivers side front door will not open from inside or outside?
http://technoanswers.blogspot.com/2012/01/ford-f-350-crew-cab-drivers-side-front.html
Car door will not close?
http://howtobyme.blogspot.com/2011/11/car-door-will-not-close.html
All power door locks not working ?
http://howtobyme.blogspot.com/2011/11/all-power-door-locks-not-working-on_14.html
Repairing car Door lock Actuator?
http://howtobyme.blogspot.com/2011/11/repairing-car-door-lock-actuator.html
How to Access car door panel?
http://howtobyme.blogspot.com/2011/11/how-to-access-car-door-panel.html
Vehicle door panel components?
http://howtobyme.blogspot.com/2011/11/vehicle-door-panel-components.html
Truck Door will not close?
http://schematicsdiagram.blogspot.com/2011/12/ford-truck-door-will-not-close.html
Where is Cars Door control Module located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-cars-door-control-module.html
Power door locks not working?
http://schematicsdiagram.blogspot.com/2011/12/power-door-locks-not-working.html
Door ajar light stays on?
http://technoanswers.blogspot.com/2012/01/door-ajar-light-stays-on.html
Door locks not working?
http://technoanswers.blogspot.com/2012/01/door-locks-not-working-on-ford-explorer.html
Front Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/front-door-dis-assembly-diagram-for.html
Rear Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/rear-door-dis-assembly-diagram-for.html
How to test Power door locks?
http://repairhelpcenter.blogspot.in/2012/02/how-to-test-power-door-locks.html
Doors will not open with Remote?
http://schematicsdiagram.blogspot.in/2012/02/lexus-doors-will-not-open-with-remote.html
How to replace Door Hatch ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-hatch-on-acura-integra.html
How to remove Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-doors-on-acura-integra.html
How to Replace Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-doors-on-audi-a4-and-vw.html
Remote will not unlock Rear door?
http://schematicsdiagram.blogspot.com/2011/12/remote-will-not-unlock-rear-door-on-gmc.html
Door locks or windows not working on car?
http://schematicsdiagram.blogspot.com/2011/07/door-locks-or-windows-not-working-on.html
This will help.
Thanks.
03 f250 4x4 5.4ltr. power windows, power locks and power mirrors don't work and door ajar lite stays on
For all types of power window problem and power windows not working,i suggest you to go through the help links given below.Click the link to go through its procedure to troubleshoot the problem :------
Door ajar light stays on? http://technoanswers.blogspot.com/2012/01/door-ajar-light-stays-on.html
power locks, power window and power mirror not working?
http://howtobyme.blogspot.com/2011/09/power-locks-power-window-and-power.html
All power windows not working?
http://howtobyme.blogspot.com/2011/09/all-power-windows-not-working-on-2003.html
driver side power window problem?
http://technoanswers.blogspot.com/2011/06/driver-side-window-problem-on-mercury.html
Driver side power window wont go up?
http://howtobyme.blogspot.com/2011/10/driver-side-power-window-wont-go-up-on.html
Power window problem
http://repairhelpcenter.blogspot.com/2012/01/pontiac-grand-am-power-window-not.html
rear door or window will not open ?
http://technoanswers.blogspot.com/2011/06/rear-door-or-window-will-not-open-on.html
How to remove door panel, door window motor and regulator ?
http://technoanswers.blogspot.com/2011/05/how-to-remove-door-panel-door-window.html
Power windows not working after car wash?
http://howtobyme.blogspot.com/2011/11/power-windows-not-working-after-car.html
---------power locks, power window and power mirror not working?
How to remove window motor and regulator on Car?
http://howtobyme.blogspot.com/2011/09/how-to-remove-window-motor-and.html
-------------Complete Diagnosis & Testing Power Windows?
http://repairhelpcenter.blogspot.in/2012/02/diagnosis-testing-power-windows.html
How to replace power window motor in car?
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-power-window-motor-in.html
HOW TO REPLACE A POWER WINDOW SWITCH
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-power-window-switch.html
How to Replace a Window Motor
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-motor.html
HOW TO REPLACE A WINDOW REGULATOR WITH MOTOR
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-window-regulator-with.html
HOW TO REPLACE WINDOW RUN CHANNEL SEALS
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-run-channel-seals.html
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-regulator.html
-----------This will help.Thanks.
1helpful
Similar electrical issues with driver's side door controls. Power locks, power window, and power mirror on driver's side are not functioning. I can manually unlock the door, but the buttons on...
CHECK FUSES FOR POWER WINDOW,CHECK FUSE FOR POWER MIRROR AND CHECK FUSE FOR POWER DOOR LOCK.IF FUSE OKAY DOOR CONTROL MODULE FAULTY ITSELF.
Doors wont lock. Windows won't work. Car thinks the door is locked because when I open the hood alarm goes off. Security light is flashing when doors are closed. Locks don't engage when driving...
Window fuse's and relay's may be up under driver or passenger side dash or behind glove box, under the hood and even under the seats, and finally on the ends of the dash. All passenger power windows and locks are controlled thru and get power from the master control switch on the drivers door. Could be a broken wire in the rubber boot going from the door to the body. You will have to eliminate each till you find the culprit. Check that all switches return to neutral when released. It could also be the body control module.
Power window, power locks ,and power mirrors don't work on my gmc envoy 2006 but the other controlers work in the vehical.
I assume you are talking about the controller on the driver's door. The Driver's Door Module is likely defective. For troubleshooting purposes, you can swap in the passenger side module to verify.
1helpful
2answers
2004 Chevy trailblazer. Power windows & locks dont work on driver side front controls. Have all ready removed and replaced control cluster on arm rest. All other wondows work at the respective door,...
Sounds like a fuse. Are you getting power to the driver door module (control cluster as you say). Below are 3 pictures for you. The first one is the location where the fuse box is located for that fuse (under drivers seat in the rear). The second picture is a diagram or the latout of the fuses. The fuse you want to check is the fuse marked "LT DOORS" or the one marked 02. It should be a 25 amp fuse. The 3rd picture is a wiring diagram for the circuit. If the fuse isn't blown check the power wire from the fuse box to the driver door control module. Sounds like a power issue. Anymore questions or diagrams that you need, feel free to email me at [email protected] and I should have and will send if you need anything else. I hope this helps and good luck.
5helpful
3answers
My passenger side front door lock won't work and my passenger side remote mirror.
Both of those are controlled by the Passenger Side Door Module inside the door itself. It is necessary to read the data from your Body Control Module (BCM) to properly diagnose the cause of the failure.
Power window not working
it sounds by the motor clicking that your power window motor is shot.....If you jump 12 volts to the terminals on the motor does it work?.................if it does you can at least get it up.......if you put the power to it and it goes down reverse the wires on the terminals and it will go up.But it sounds to me like you need a new one.
hope this helps!..............Good luck!
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
