SOURCE: need the manual for lp-1000. need to add the oil
Please try this, if not successful post back (below)
Black & Decker
Go To “ServiceNet/” link
Bottom of center column “Need a Manual?” Enter model number, “YourModel” in window.
SOURCE: I have a b and d alligator lopper that has never
Information on your product, inlcuding a link to the Manual may be found here:
http://servicenet.blackanddecker.com/Products/Detail/LP1000
A high quality bar and chain oil or SAE30 weight motor oil should be used for chain and bar lubrication.
The use of a vegetable based bar and chain oil is recommended when pruning trees. Never use waste
oil or very thick oil. These may damage your chain saw.
- Before first use and every ten minutes of use you must oil the product with the recommended chain oil. Open the oiling cover and insert the bottle into the oil filling hole apply pressure to the bottle once to dispense oil.
- This should be adequate for about 10 minutes of cutting depending upon cutting speed and type of wood.
- The hole feeds the oil through to the chain onto the chain bar and an excessive amount of oil applied to the unit could mean the oil drips from the unit around the jaw area. This is normal and is nothing to be concerned about.
