20 Most Recent Black & Decker Black Decker Lp1000 Alligator Lopper Chain Saw Questions & Answers
Information on your product, inlcuding a link to the Manual may be found here:
http://servicenet.blackanddecker.com/Products/Detail/LP1000
A high quality bar and chain oil or SAE30 weight motor oil should be used for chain and bar lubrication.
The use of a vegetable based bar and chain oil is recommended when pruning trees. Never use waste
oil or very thick oil. These may damage your chain saw.
- Before first use and every ten minutes of use you must oil the product with the recommended chain oil. Open the oiling cover and insert the bottle into the oil filling hole apply pressure to the bottle once to dispense oil.
- This should be adequate for about 10 minutes of cutting depending upon cutting speed and type of wood.
- The hole feeds the oil through to the chain onto the chain bar and an excessive amount of oil applied to the unit could mean the oil drips from the unit around the jaw area. This is normal and is nothing to be concerned about.
Black & Decker... | Answered on Aug 05, 2013
It's possible that one of the motor brushes may have been damaged--also check their spring tension. The battery may be charged, but have no capacity. You will need to measure the battery voltage directly when trying to start the motor. If it falls to zero, then you either have a poor connection at the battery, or it needs to be replaced (under warranty?). Hope this helps!
Black & Decker... | Answered on Jun 29, 2010
This unit has 3 separate 12v SLA batteries, yes(?).
Remove or disconnect the batteries and try charging each battery separately with a 12v automobile battery charger.
I suspect one or more of the batteries has not taken a sufficient charge and is "fooling" the charger that came with the mower.
Once you have separately charged all three batteries, reinstall and try.
Black & Decker... | Answered on Oct 04, 2020
When checking for a spark you must make sure the spark plug is well earthed against the cylinder, and give the starter a good pull, if there is no spark try a new clean plug ( make sure the ignition switch is on ) if all this fails then unfortunately you may well need to fit a new ignition coil, this will be situated under the covers against the flywheel.
Black & Decker... | Answered on Feb 01, 2020
Switch may be shot. If it was stored in a damp spot that could do it.
Black & Decker... | Answered on Jan 20, 2020
The first thing to try is the Black & Decker website. Second use Bing, duckduckgo, Google, Etc
Black & Decker... | Answered on Oct 16, 2019
  • there is a safety on it that has to be pushed down before you pull the trigger to start it. if that safety has a problem or is not fully depressed it will cause the weed eater not to start
Black & Decker... | Answered on Jun 15, 2019
Black & Decker Black  Decker Lp1000 Alligator Lopper Chain Saw Logo
Popular Tags
15 questions posted
Top Black & Decker Garden Experts
Marvin
Marvin
Mike
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
View Most Popular
  • Black & Decker Garden
Most Popular Question
b d alligator lopper never
  • Garden
