It is just be a matter of synching the blue tooth system of the blackberry to that of the PS3. Assuming the PS3 is not currently connected to the web or connected to a modem, you should be able to search for the PS3 by using the Bluetooth search tool in the Blackberry setup menus. Then for headsets,set those up through the PS3 by turning on the head sets, and then using the Blue tooth set up utility of the PS3 to search for the head sets.
Otherwise If you do not have Wifi active currently and don't have good cellular coverage in your area, you can use a Wifi Bridge Dongle (connector cable) like this one, there are others available too.
http://www.espow.com/wholesale-wifi-bridge-dongle-wireless-for-dreambox-xbox-ps3.html
to connect the PS3 to your home computer and use it as the hub assuming you ahve it connected to DSL or broadband. headsets would set up the same way.
