Your flywheel has come loose on enj., this throws the timing off so it is firing at all different times except for when it's supposed to. therefore raw fuel is running right through the cylinder and out exhaust, If you are lucky you won't have to replace the 60.00 flywheel! remove fan side of case,and remove blower wheel, then flywheel nut then flywheel, it has a built in key in it, usually this is wasted from coming loose, make sure you use loctite and an impact to tighten flywheel nut back after you repair/replace flywheel.
