20 Most Recent RTO Echo 25.4 Cc Backpack Leaf Blower - Pb-265lc Questions & Answers
new spark plug is first option as when hot plug or cil pack will get hot and short out causing misfire will lead to none starter
RTO Echo 25.4 Cc... | Answered on Jul 29, 2012
Simply use a srewdriver to adjust the mixture screw. Its located on the carburator. Clockwise is lean, counterclockwise is rich. If you can get the thing to idle, let it warm up first. Adjust the mixture lean until it just starts to sputter, then adjust it rich 1/2 turn. Test full throttle, if it sputters, you can adjust the mixture a little more rich so that it runs good at full throttle.
I would suggest steering away from investing in 2 cycle engines for a pawn shop, unless you can see them running. These little engines are very picky and they only run well if they are in good shape. If you cant get them to start easily, there is probably a lot of internal wear/damage and these engines are hard to find parts and are not cheap to fix.
Bad investments would include 2 cycle leaf blowers, trimmers, chainsaws, boat motors, and motorcycles that do not start easily. Believe me, they are a headache to fix.
RTO Echo 25.4 Cc... | Answered on Mar 27, 2012
White smoke means water. Change fuel filter and clean tank.
RTO Echo 25.4 Cc... | Answered on Feb 16, 2012
If its a two cycle engine it sounds like its loading up on fuel.. Need to lean out the fuel on the carb. Not much or it will be to lean an stick the piston..
RTO Echo 25.4 Cc... | Answered on Oct 06, 2011
This is easy enough to check. There are 4 screws that secure the recoil starter to the engine. Remove these 4 screws and remove the starter assembly. Pull on the rope and see if the starter is operating properly. If not, go to your local Echo dealer and get a new one...they are about $30. Also try to turn the starter cup by hand to see if the engine is locked up. If the engine is locked up, remove the spark plug and try to turn the starter cup again. If it is still locked up, then the repairs would cost more than a new blower.
RTO Echo 25.4 Cc... | Answered on Dec 21, 2010
Check the exhaust port upstream from the muffler and make sure it is not restricted with carbon. Mine was less than half way covered over with carbon. Scraped out carbon, checked muffler and screen(ok), back-blow the fuel line harness including the fuel filter and fuel tank vent and took carb apart and blew out all passages, not replacing anything and now runs fine. Would not rev past high idle before. Be sure gas is FRESH and mixed at 40-50 to 1. Hope this helps.
RTO Echo 25.4 Cc... | Answered on Nov 20, 2010
Try removing the muffler and look inside of the exaust port, you should be able to see the piston in the full opening of the port. If you can, try starting and running at wide open throttle. If it runs fine( a bit loud, so wear hering protection), then you have a plugged or partialy blocked muffler or spark arestor. Sometimes rich mixture can cause excessive carbon build up.
Hope this was helpfull.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
RTO Echo 25.4 Cc... | Answered on Nov 07, 2010
i have aecho pb 260l backpack style leaf blower and it will not start. it turns over well and has spark and reasonably new fuel. any thoughts
RTO Echo 25.4 Cc... | Answered on Oct 09, 2010
Maybe a plugged intake. Maybe a broken impeller. Air filter partly plugged causing reductiion of power. Check those things and I think you will find the problem. Good luck...Lee
RTO Echo 25.4 Cc... | Answered on Nov 09, 2009
blown moter from bad gas mixture
RTO Echo 25.4 Cc... | Answered on Aug 21, 2009
It's eithe your coil ha heat soak and needs replacing or your fuel circuit isn't venting properly and is creating a negative pressure
RTO Garden | Answered on Nov 22, 2013
RTO Echo 25.4 Cc Backpack Leaf Blower - Pb-265lc Logo
Popular Tags
18 questions posted
Top RTO Garden Experts
Dennis Key
Dennis Key
Nick Olsen
Bill Boyd
Are you a RTO Garden Expert? Answer questions, earn points and help others
View Most Popular
RTO Garden
  • RTO Garden
Most Popular Question
craftsman weed eater misfires after
  • Garden
