Washing Machines Logo
Anonymous Posted on Aug 11, 2017
LG washing machine doesn't heat water
Hello, I have LG WD 80130 wahshing machine. It doesn't heat water. I checked the heating element and the cables and they are OK. Also I checked the thermostat with multimeter when the water is hot (80C) the resistance is about 15 kOhm and when the water temp is regular (20C) the resistance is about 55 kOhm. Does the thermostat works properly? What could be the problem? Thank you, Michael
Pieter Vleeshouwers
Level 3:
  • LG Master 2,029 Answers
  • Posted on Aug 11, 2017
Pieter Vleeshouwers
LG Master
Level 3:
Answers
2029
Questions
0
Helped
4113851
Points
7389
Bad cable or slide contacts or even a connector block is disconnect from a connector , it can happen when the If the motion result of the drum was too large, and can happen when a suspension eye was broken on the drum to know every brand has its own remarkable safety tricks on marketing technical arts. ( or its only a circuit thermal circuit breaker that has a problem with a slide cable connector on it or the breaker itself is damaged. Track the circuit from the program clock you can sometimes find a remarkable defect in modern washing machines.
LG washing machine doesn't heat water - thermostaat -frgcg3xuc2kvfx0y020q1wwu-5-1.jpg
LG WD 80130F Manuals
5 Related Answers
Anonymous
  • 68 Answers
  • Posted on Jul 29, 2008
SOURCE: LG WM2688.. water heater not working
I would also check that the unit is grounded. A non grounded unit can cause problems with the electronics
Please rate this solution
Anonymous
  • Posted on Aug 16, 2008
SOURCE: LG washing machine error codes
I have today the same error code on model WD-11155FB. This code means that the speed of the electrical motor can no longer be controlled. The velocity sensor placed just behind the motor is probably damaged but it can be also the electronic board where is connected this sensor, or the wiring between these two items.
Anonymous
  • 3 Answers
  • Posted on Feb 13, 2009
SOURCE: Bad smell in our washing machine LG Front Loader WD-8074
I had the same problem.  It's a design flaw with all HE's I have learned, they are too efficient.   I visited my local Sears store and purchased WasherFresh.  I initially tried Affresh made by Whirlpool, did not help at all.  WasherFresh I initially had to use 3 tables to get rid of the buildup and now I use it once a month and now our towels do not smell moldy.  Hope this helps.
Anonymous
  • 6784 Answers
  • Posted on Jul 23, 2009
SOURCE: LG WM2355C water leaking under machine after washing finished.
HI, you will want to Inspect the water supply connections. this is a good spot to check first. there may be a loose connection here, causing the leakage. Next, Inspect the drain hose. Check to make sure that it is tightly connected to the drain pump. replace if needed. Last. Inspect outer tub/basket for cracks or corrosion.
You will find the issue in one or all of the above stated check points.
Anonymous
  • Posted on Oct 05, 2009
SOURCE: lg 801 3f washing machine. 15 seconds after selecting any cycle a
I had the same problem. Redistributing the clothes inside the machine seems to do the trick. Even though the clothes seemed evenly distributed and I had far less than maximum capacity in the machine- it seemed to think that something was out of sync- simply moving the clothes around did the trick!
1helpful
TE code wm2688hnm
proceed with common sense and logically, fix it use the Vom or DVOM .God bless you
For this error code you need to check both the water heater or element and thermistor, basically the washing machine is reporting a fault on the heating circuit with this fault code but it is not capable of identifying exactly where the fault actually lies.
On non-display panel models this fault code is denoted by the lights for 95, 60, 40 and cold being lit or flashing.
  • Check water heating element
  • Check heater for contunuity,
  • Check steam heater for continuity usually
  • Check thermistor or temperature sensor
  • Check the thermistor resistance,
  • Check wiring to water heating element
  • Check connections to water heating element and temperature sensor
LG WD 80260 NP washing service manual / circuit diagram
tE is heating error. Water not heating, Could be a faulty element, faulty wiring, faulty temperature sensor or faulty control board.
F05 error code appears on the front panel and water will not empty but if i hold the waste pipe low into a bucket and the water then empties the cycle continues. machine is a hotpoint ultima wt900 1600...
hello there and thank you for choosing fixya
This is a verry common issue with these dryers Please read this solution fully below
F/05 Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
  • Check the Water Temperature Sensor, Heating Element and Element Relay
  • Check connections to the Sensor, Heating Element and Relay
Gew9200lw1 whirlpool dryer turns on, spins but doesn't heat up
hello, this is Mike. If your dryer turns on, tumbles, but there's no heat, I would bet that your heating element is toast. If you can access the terminals to the heating element, you can test them for continuity using a simple inexpensive tester. No continuity means they need to be replaced. If you would like some assistance with how to go about this and possibly fix the problem yourself, feel free to contact me. I would be happy to help you. thanks
Does the hotpoint model 9534 have a heating element in it to heat up the water if the temperature of the incoming hot water is not high enough for the set wash? Because when it only has cold water going...
yes it has an element. first thing is to make sure you dont have the "econmy" button selected as if you do this causes the machine to skip the heating stage.
if not its an element you need part number 1601318.
remove the front facia and panel and you will find the element in the front of the drum
Washing Machine Aquarious Ultima the screen shows F 05 ? it does not finish washing and the door can not be opened
Hello there:
Washing machine code f-05
Hello there
2answers
No, these heater normally should last a long time.  Are you sure the heating element is bad and not the control board that feeds the power to the element?
2answers
Washer dryer not heating up
both the 'wash' & the 'dryer' have their own heating elements, If the 'wash' completes its full cycle including 'spin', then I suspect this heat element is ok.Re the dryer, most likely the heat element circuit is 'open circuit' somewhere, could be  the element, thermal fuse, thermostat, or a wire burned out
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
