Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Washer dryer not heating up
Hello, my hotpoint wd 440 washer dryer does not wash hoy and also does not heat up in drying mode all other functions seem to operate, this leads me to believe its the heater element or part of. Im not sure where this is could you tell me where to look and also how to test it. thank you
Posted by harry 245 on
  • Anonymous Feb 14, 2008
    locating the thermostat
firesign
    Problem Solver:
  • 9 Answers
Firstly, try a 90 degree wash. If this does not heat up you can acces the heating element very easily.
Put the machine in a clear area. Put a thick cloth or blanket on the floor and gently lay the machine on its left side, looking from the rear.
Remove the inspection cover at the back and you will see two large connections at the bottom of the drum. This is where the element is. just unscrew it, pull out the element and change it.
It is much easier to do this with the machine on its side as you can get at things from the back AND the bottom!
If you wish, you can get a test meter, remove one connection and check the element for continuity before you remove it
Posted on Feb 29, 2008
keith wagstaff
  • 64 Answers
Both the 'wash' & the 'dryer' have their own heating elements, If the 'wash' completes its full cycle including 'spin', then I suspect this heat element is ok.Re the dryer, most likely the heat element circuit is 'open circuit' somewhere, could be  the element, thermal fuse, thermostat, or a wire burned out
Posted on Oct 23, 2007
Dryer won't dry is there a filter which could be blocked
It could be the heater element if the machine is operational but not heating, or check the function buttons mine has a cool button that doesnt dry it just airs out laundry.
Jul 28, 2014 | LG WD-12126RD Front Load Washer / Dryer
I have a Hotpoint Aquarius WD420 washer/dryer that is not heating the washing water, yet does heat when in drying mode. Does the machine use the same heating element for washing and drying, or are there...
There is a seperate element for the water heater. so likely to be a faulty heater or thermistor which is fastened toi the element
You really need a test meter to determine which part is faulty.
Dec 27, 2010 | Hotpoint Washing Machines
Will not pump out
you will filter is blocked if you pull the machine out and the the waste pipe drop into a bowl or a bucket the water should run out the filter is underneath the tub black hose going to pump held on by screw clip remove back panel to see this UNPLUG MACHINE FIRST. undue screw clip pull down black pipe gentle there is a ball in there then a plastic filter clean and replace.
Jun 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarious wd 440 two years old tripping main board
A faulty heater in both a washing machine and dishwasher will trip swithes because they both cause an earth........the chances are you heater needs replacing......the reason its tripping after a short period is probably beacause the cycle doesnt start heating the water until after approx 15-20 mins depending on the cycle chosen
Mar 28, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD 865- washes ok, dryer won't work makes loud popping
sounds like the dryer heater element has worked loose perhaps and shorted out against the metal dryer box which sits on top of the drum.
best to get an engineer out i'd say.
Jan 14, 2009 | Hotpoint Aquarius WD63 Front Load...
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
Oct 20, 2008 | Washing Machines
Hotpoint BWD129 1200 spin - unwanted drying cycles
This is more a workaround than a solution. When you choose the washing programme (say "D") and push the on/off button, two lights will flash, the "door locked" and the "drying" one. Now turn the "drying programme" button until the "drying" light stops flashing (in my case, this is true when I set the drying programme to 40°C). Then start the washing mashine.
Seems like the function of the drying programme button has shifted against the settings written on the button...don't ask me why! Of course, no guarantee but works for me. Please let me know if it does for you.
Oct 13, 2008 | QuietLine WD-9900 Front Load Washer /...
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
Hotpoint WD 440
FIRST OF ALL THE PERSON WHO INSTALLED THE MACHINE SHOULD HAVE REMOVED THE TRANSIT BOLTS YOU MAY BE LUCKY THAT ONE OF THE SHOCKS MAY HAVE COME OUT OR A SPRING MIGHT HAVE BROKEN
Jul 13, 2008 | Hotpoint Aquarius WD63 Front Load...
WD440G. No heat in wash and dry.
I would first check exhust vent to make sure it's not clogged if so it will cause your heating sensor to shut down
Mar 28, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
405 people viewed this question
Top Hotpoint Washing Machines Experts
Eric Taylor
Richard C Cohen
Richard C Cohen
Onofrio Taverna
Onofrio Taverna
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
