Technics SA-AX540 Receiver Logo
A
Anonymous Posted on Oct 26, 2011
Where can I get a remote for a technics sa-ax540 receiver??
Level 3:
  • Technics Master 17,130 Answers
  • Posted on Oct 27, 2011
Technics Master
Level 3:
Answers
17130
Questions
0
Helped
3635724
Points
52372
Please check this link for unversal remote that will match if you are not able to get a Technics remote:
http://www.espares.co.uk/search/remote-controls/p/1090
4 Related Answers
Anonymous
  • 4234 Answers
  • Posted on Mar 02, 2009
SOURCE: Technics SA-AX540 Receiver
It is unlikely that the display itself is faulty although it can happen. The typical problem is either the backlight is defective or the suply to the unit has a bad connection. If you can solder, try resoldering the pins on the display itself. The pins on the ends are the power and ground. I don't recall whether or not your model has a separate back light bulb or not. That too could be burned. Chack for that too.
Keep us posted,
Dan
Anonymous
  • 1489 Answers
  • Posted on Oct 01, 2009
SOURCE: Ipod Connection
Here's a link with a lot of discussion on how to do that.
Charlie
http://forums.ilounge.com/archive/index.php/t-37576.html
Anonymous
  • 8546 Answers
  • Posted on Feb 21, 2011
SOURCE: My Technics SA-AX540 AV Control
Heat?
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Anonymous
  • 8546 Answers
  • Posted on Aug 20, 2011
SOURCE: I am looking for a remote control for an old
It's a eur647130. Web searching turns up a bunch of them.
My display wont come on on my technics receiver sa ax 540
  • Below the picture the underlined word should change from processing to Get Manual
  • TECHNICS SA AX540 SM Service Manual free download schematics eeprom repair...
WANT TO GET OUTPUT I.C FOR STEREO AMPLIFIER TECHNICS MODEL SA-AX540
Try Ebay or Audio Lab of Ga.
If it's a single module , it wont be cheap
I have bought a SA-AX540 when this unit probuced
pop into comet or currys and ask them for tecknics customer sevices number ring them and the wil probly send you one you might have to pay potage
Ipod Connection
Charlie
Keep us posted,
Dan
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
