Question about Technics SA-AX540 Receiver
I have bought a SA-AX540 when this unit probuced
I have bought a SA-AX540 when was this unit produced and where can I buy or find the manuals for this unit. I would like to build around it.
Thanks for any help....Brad
Posted by bking29 on
Anonymous
    New Friend:
  • 32 Answers
Pop into comet or currys and ask them for tecknics customer sevices number ring them and the wil probly send you one you might have to pay potage
Posted on Nov 27, 2009
My display wont come on on my technics receiver sa ax 540
  • Below the picture the underlined word should change from processing to Get Manual
  • TECHNICS SA AX540 SM Service Manual free download schematics eeprom repair...
Where can I get a remote for a technics sa-ax540 receiver??
Please check this link for unversal remote that will match if you are not able to get a Technics remote:
http://www.espares.co.uk/search/remote-controls/p/1090
Ipod Connection
Here's a link with a lot of discussion on how to do that.
Charlie
http://forums.ilounge.com/archive/index.php/t-37576.html
It is unlikely that the display itself is faulty although it can happen. The typical problem is either the backlight is defective or the suply to the unit has a bad connection. If you can solder, try resoldering the pins on the display itself. The pins on the ends are the power and ground. I don't recall whether or not your model has a separate back light bulb or not. That too could be burned. Chack for that too.
Keep us posted,
Dan
2answers
Su-g91
Have you checked the fuse in the unit?
2answers
Technics sa-g78 no sound from front speakers
This happens on mine also. My theory is a relay. If you turn the volume up (Waaay up) momentarily, you "burn through" the oxidation on the relay and the sound comes back - for awhile. Some day, I'll get in there and replace it with something more robust.
Technics receiver SA AX540 overheating
is the fan turning on? many models like these have a cooling system (fan) that kicks up when the volume is turned to a certain level. if your fan has never been on, then chances are some of your soldering points have shifted or gotten a little messed up over time from the heating/cooling effect. this model runs extremely hot especially right where the vent is on the top of the cabinet. make sure that it is not in a shelf or enclosed area. dont stack other items on top of it. use an external device to control the volume so that you can have the receiver volume at a fixed level where the fan will turn on. if your sound still doesnt work, you should consider buying a new receiver or try your local craigslists forum. make sure if you buy a new one, that it is a more expensive model from a brand like sony and check the model online for known problems. stores like best buy offer extended warranties on most of their products which are very wise investments. good luck sinbad
Technics SA-AX540 Receiver Logo
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
 Francisco Mauricio...
Morne Olivier
Morne Olivier
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
