The outputs I can't make out. There are two, one starts with a SV
SOURCE: Technics SU-G91 OVERLOAD PROBLEM
I had the same problem. As soon as the volume reached about 24db it would go into overload. I was able to fix it by soldering all the connections on the larger power module. The one connected the the heat sink. When I took it apart there where several solder points that had come loose.
SOURCE: Technics SU-G91 Left channel bad
Did you ever find the solution to the left channel issue? I have the same problem with mine.
