Jacuzzi Balboa R574 System for 1 2 Speed Pump Value 52221 05 Logo
Posted on Sep 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hot tub keeps running all night keeping me awake. How do you shut it off? It's a Great Lakes.
Bath and Spa Parts Online
Level 2:
Scholar:
  • Expert 47 Answers
  • Posted on Sep 21, 2011
Expert
Level 2:
Scholar:
Answers
47
Questions
0
Helped
21363
Points
132
If the system is the Jacuzzi 52221-05 system mentioned in the subject header, there could be a stuck relay causing the problem and you might need to get a spa technician out to assist you in repairing the problem. However...
If it is a Great Lakes system as mentioned in your message body, then there could be a programming issue allowing the filter cycle to run continuously. Provide a model number off of the Balboa control. Then we can provide you an instruction manual or reference card to assist you in resolving this problem. you can also search our online manuals at our website. You can find them online at:
BALBOA WATER GROUP INSTRUCTION MANUALS
  • Anonymous Aug 04, 2013
    It is a Great Lakes Traverse Bay model. I replaced the heater (Balboa 58074) about 3 years ago. The heater has 1 sensor and 1 pressure switch which did not come with the heater, so they are original. Is this the pressure switch that will cause the "FL" code?
2answers
Great lakes hot tub heater control not responding
Check the thermocouple on the water pipe.
Jul 16, 2022 • Pool & Spa
No power, great lakes hot tub hear click like breaker tripping,down below in hot tub could it have bad internal fuses?
Charles, sorry I just re-read your question. The click you hear is likely a contactor if its an older model, and if it clicks its probably not the problem, just means its getting voltage. I would start by looking at the high limit switch. Look for a little reset button. A high limit switch trips when it senses high temperature, often from heater trying to run with Inadequate water flow.
Feb 22, 2017 • Pool & Spa
My great lakes hot tub pump is on low speed and it will not shut off. I have it set to Ec mode.
One of two things either the thermostat is bad or the relay that controls the pump motor is stuck
May 27, 2016 • Pool & Spa
2answers
Our fan keeps turning off in the middle of the night and then immediately back on. This process will repeat all night until you turn it off.
The fan might be set to something called "night mode" (which I have no idea why it's called that because it just keeps me awake). Try changing the mode that the fan is set to. Or, refer to the owners manual.
I have a 2004 great lakes hot tub with a balboa controler. My hot tub heats up fine when the pump runs on high but the temp light never comes on when the pump runs in low.
check to see that the flow switch is working properly, it may not have enough flow on low speed to allow the heater to turn on. Make sure your filter/s is/are clean. If you have a pressure switch instead of a flow switch, it may need to be adjusted or replaced.
28helpful
2answers
Reset error code hot tub
tub is in sleep mode usually to change u must press temp button then light button you want to b on standard mode STD
Top Jacuzzi Garden Experts
john h
Jay Finke
Jay Finke
CJ Rock
CJ Rock
Are you a Jacuzzi Garden Expert? Answer questions, earn points and help others
