20 Most Recent Qca Spas Jewel Series Topaz Plus Hot Tub Questions & Answers
The display panel on my hot tub shows a lock and none of the function keys respond when touched
didnt specify if you had a 4 8 or 10 button panel your unit is locked the only control that will work is temperature your owners manual has how to unlock it under side panel the following link is for an 8 button panel and the instructions are on page 6 http://qcaspas.com/media/pdf/Jewelp3-8Btn.pdf
9/1/2016 1:12:43 PM • Qca Spas Jewel... • Answered on Sep 01, 2016
I am using a product to find a small leak in the hot tub, but they told me to turn off the heat and keep the circulation going. How do I turn off the heat without turning off the tub?
drop the temperature all the way down and turn on unit like you would normally do [but depending on amount of time the product needs to circulate may need to turn on a few times ] or reset set the filter time for longer
9/1/2016 12:59:23 PM • Qca Spas Jewel... • Answered on Sep 01, 2016
Hot tub pump noisy, heats to set temp, fl error code
This sounds like your motor is going out. When they get noisy and run really hot is when they go outRodUS Parts Center
8/1/2015 6:21:50 AM • Qca Spas Jewel... • Answered on Aug 01, 2015
2answers
What does the pr code mean? I am getting this after draining my tub and refilling....
pressure tap on pressure switch or you might have air in lines
4/11/2015 12:28:10 AM • Qca Spas Jewel... • Answered on Apr 11, 2015
I have a vitabath e600 tum shuts off after 45 min
sounds like the recirculation pump is overheating and tripping the breaker if the pump is ok could be heating element shorting out
10/4/2014 2:24:42 AM • Qca Spas Jewel... • Answered on Oct 04, 2014
An Emerald Spa 1998 keeps tripping the breaker
with power off take cover off control box remove heater element lead make sure to take a picture or a drawing to see where they go back turn on breaker with wires taped up if it doesnt blow breaker you need a new heater element
8/9/2014 2:34:15 AM • Qca Spas Jewel... • Answered on Aug 09, 2014
2answers
How do i replace a pressure switch in a QCA spa
open cover the powerpack has a silver pipe running along bottom that has unions on both sides there is a pressure switch mounted to pipe. on pressure switch two wires if doesnt work make sure you have voltage on both sides of switch if only voltage on one side bad switch if voltage on both check recirculation pump to see if working also make sure filters are clean
8/8/2014 3:34:47 PM • Qca Spas Jewel... • Answered on Aug 08, 2014
Signature Titan II keeps tripping the breaker
check to see if recirculation pump is working if so check to see if heater element is not shorting out
8/3/2014 4:20:03 AM • Qca Spas Jewel... • Answered on Aug 03, 2014
0answers
0answers
I have a qca jewel spa the heater only runs when
I would assume this is by design. If water were not flowing through the heater it would constantly cycle and mineral deposit would accumulate on the heating elements much faster and shorten their lifespan.
11/5/2013 5:14:35 PM • Qca Spas Jewel... • Answered on Nov 05, 2013
2answers
Reads OH but still cold
you either have a bad temperature sensor (check the wires for damage) or a bad circuit board. I would recommend replacing the temp sensor first. If that doesn't work, pull the board and take it and have it tested.
12/11/2012 12:57:27 AM • Qca Spas Jewel... • Answered on Dec 11, 2012
OH error QCA spa High jets work and heat
OH is the overheat code.Your spa temperature is set above 108, or your thermostat is faulty & not reading correctly.
1/26/2012 9:47:47 PM • Qca Spas Jewel... • Answered on Jan 26, 2012
Qca Spas Jewel Series Topaz Plus Hot Tub Logo
Popular Tags
58 questions posted
Top Qca Spas Pool & Spa Experts
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Qca Spas Pool & Spa
  • Qca Spas Pool & Spa
Most Popular Question
winterize hot tub qca jewel model suv
  • Pool & Spa
