20 Most Recent
Qca Spas Dream Series Dream Master Hot Tub with Flex Cover Questions & Answers
I am getting a Pr code and the tub is not coming on at all
follow this steps and fix it. God bless you
If the unit won't start, make sure power is on at the electrical outletor the electrical panel Then test the pump and the motor. Check for and repair broken wires or loose or corroded terminals. If necessary, have the pump switch control tested and serviced professionally.
If the jets do not work, clear a blocked water intake of hair and other particles (see below) or replace a broken jet (see below).
If the water in your spa or hot tub is too hot or too cold, check to see if the high-limit reset switch has been tripped and, if needed, reset it. Adjust the thermostat setting and have the thermostat serviced if the problem persists. If necessary, test and replace a faulty heating elements
What does FL mean on my hot tub??
FL could be a code for low flow. If you have no circulation this sounds like it. If your pump runs and you have no flow you could have a problem with your pump. Or if you have the tub drained then it could be an air lock, if you open the drain valve till you get water out that should fix that. Also check to be sure the isolation valves are open under the spa. I hope this helps.
Why does the spa trip the gfci when I turn the jets on high?
You need to make sure that it is a real GFCI and not a spark detection fault interrupter. When the pump is turned all the way up it may be causing a large spark that the SGCFI is detecting. If it is not that then there is a parasitic floating fault that is causing the issue.
I have this pump modelpf-40-2n22c cam i chang it out for this model numbert55cxcas-1179
If the water flow according to each pumps spec's match up and the plumbing lines up, with little or no modification, then all is good.
but...
remember this, if the water flow does (GPM's) not matchup, you will ever overdrive your hydraulics system causing premature leaking, or if undersized, your jet action will be diminished!
you can find this information by obtaining the "Pump Curve" chart from each pump manufacturer.
btw... The numbers you provided don't help much.
Make and model name of each pump??
