SOURCE: maxent MX-42VM11 won't turn on
I had the identical problem (clicking sounds, no picture, but just the sound). I took Richdogg's advice above, but it didn't work out for me (lost money on the purchase of the part) - no offense Richdogg as I'm sure that was the problem in your TV. I later found out that the problem was with the Y-Sustain (also called Y-Main) Board. As with most parts in this TV, this is also made by Samsung and used in Maxent, Magnavox and a number of other 42" TVs. The part number is LJ 92-01256A (using LJ 41-02668A also give you the same part number). Hope others will find this useful.
- Kamal
SOURCE: Maxent MX-42VM10 42 Remote
Trying to program a universal remote can sometimes be a frustrating process. Successful programming of a universal remote depends on whether the universal remote manufacturer included our company’s information in the remote when it was assembled.
Then a cable company (ie., Comcast) or satellite provider (ie., Dish Network) orders their decoder box and universal remote control from a manufacturer (ie., Scientific Atlanta, Motorola, etc.), the decoder box manufacturer provides a list of all the possible remote controls this universal can duplicate. From that list the cable company or satellite selects which manufacture’s products to include on their new universal remote. Once those manufacturers names have been decided, they are placed on the universal remote and a numeric code is assigned. If they choose not to include our company on the universal remote, the universal remote may not access the Maxent screen.
If you cannot locate Maxent on the list provided to you by the universal remote provider, please try the following:
Through contact with various cable and satellite content providers we have developed a list of the most common numeric codes that are used with universal remotes.
Content Provider/Most commonly used code
Comcast: 1755
Comcast (ML-3251HLT Model): 0054
Insight: 1755
Direct TV: 11755
Dish Network: 742
Cable Vision: 165
Adelphia: 0156, 1755
Universal: 0762
One4All: 0036
Time Warner: 0230
We have identified other manufacturers of display products that have similar remote control information to ours. Depending on the universal remote you are using these manufacturers may work. Please use the documentation that accompanied your universal remote, and look up the following companies. Input the numeric code associate with that company.
Gateway
Sampo
Viewsonic
Magnavox
Phillips
Marantz
Pilot
If the universal remote you are trying to program contains a Code Search (the remote will scan through all the codes contained within the universal remote) function, we recommend that you try that procedure. It is possible that there may be another manufacturer code that may work with our monitor.
You may also want to try a Learning Remote from another manufacturer. This type of remote control can absorb or record the information coming directly out of the Maxent remote control. The learning remote then duplicates that information and acts like the Maxent Remote control. This type of remote can also record the signal coming from your other universal remotes in the same manner. In which case you can use this learning remote for your entire audio video system
SOURCE: Control Remote Codes
Mike,
Code 246 is the correct code for my Maxent plasma for my dish network remote. Remote is 5.3IR and it was made by EchoStar Technologies Corp. Part #142301. If yours is the same, good luck.
jerry
SOURCE: I have a 3 year old Maxent MX-42VM11 plasma tv with no pic/sound
swollen capasitors, replaceing will cost $500, so best to get another one, 42'' samsung will sell for about $800. the pn42a450
once a plasma has a problem, fixing it or not, more problems will occure, trust me, i am the flat pannel guru.
