Question about Maxent MX42X3 42 in. HD-Ready Plasma Television
Tv flickers when first turned on. This can last for several seconds to about a minute.
Posted by ca_baby on
Anonymous
  • 14 Answers
I have encountered this exact same problem with 2 Maxent MX-42X3 Plasma TV's. I found that C766, a 220uF, 16V surface-mount electrolytic capacitor on the main board is bad. This capacitor is located just to the left of the green multi-fin processor heat sink. This capacitor will test good using capacitor meter or an ESR meter, but if you spray it with Freeze-It with the power on, you will find out that this is the problem! To get it out, I found I had to remove the little 10uF 16V surface-mount capacitor just to the left of it. I then replaced these 2 capacitors with regular (radial), high-temperature, low-ESR capacitors. I cut the leads short, and bent the ends out just a little bit so you can solder them back onto the surface-mount pads. You can get these parts from Digi-Key Corp. I used Digi-Key part # P12383-ND ($0.32) for the 220uF capacitor, and P11212-ND ($0.30) for the 10uF capacitor. Both of these capacitors are rated for 25V and high temperature, so they won't go bad again. You can purchase surface mount capacitors there too, but I find them very difficult to solder back into those locations due to the tight placement of other capacitors in that area. Be careful, and good luck!
Posted on Nov 16, 2009
  • apollo13519 Mar 19, 2011
    Are you shure that the cap that you say to the left of C766 is a 10uF C734 on my board it is a 22uF 16V?
Anonymous
    Problem Solver:
  • 8 Answers
Sounds like you have a loose lamp or connection problem with the back light inverter to Lamp.
Try taking it appart and make sure the Lamps have been inserted properly into it's clips.
Most likely by now it is charred black from arching. Each time this happens the connection will get worse.
Eventually it won't work.
Posted on Aug 14, 2009
Repair tv
You didn't say anything about the model or make but a lot of times this comes from bad capacitors...try this...on the open fins on the back of the TV, try putting a blow comb on there and set it on low and leave it there for about 3 minutes, turn the set on and see if it comes right on, if it does there are bad caps on the power board, it could be replaced or you could repair it yourself for a couple dollars
Dec 17, 2017 | Zenith R56W36 56" Rear Projection...
Cannot set time @ date for Ohsen watch...AD0721...thanks
(A=LIGHT,B=MODE,C=START,D=RESET)
1.How to use the luminescence Any time indication,Press A the Luminescence will last for 3 seconds.
2.How to view date? Standar time indication, press C "month/ date" indication.
3.How to switch 12/24 hour systems In the normal mode, press B twice and press D twice ,then hold C until 24 hour system is actuated, then press B for recovering.
4.How to check alarm ring and alarm time? Standard time indication,press D alarm time indication.
5.How to set alarm time? Standard time indication,Press B twice. The hour area flickers,press C to set the hour. After setting hour ,press D,the minute area flickers, press C to set the minute. Last press B for recovering.
6.How to set alarm ring? In standard time indication mode ,Hold D then Press C this will toggle alarm symbol on & Off.
7.How to set Hourly Chime? In standard time indicationmode, Hold D then Press B DAY OF WEEK area toggle on and off.
8.How to use stopwatch(1/100 seconds) Press B,then Oress C for 1 timing; Press D for multiple timings. Press D once more to continue operation after multiple timing. Press D for 1 timing; press C once and press Dtwice for multiple timing. (1)Max range of the stopwatch is 23 hours 59 minutes 59 seconds. (2)When timing within 30 minutes, the watch indicates: minute/second/1/100 second (3)When timing beyond 30 minutes, the watch indicates:hour/minute/second
9.How to adjust time, date,day of week (1)Standard time indication,press B twice ,the second area flickers, pressC to adjust second. (2)Then press D the Minute area flickers,Press C to adjust minute. (3)Press D the hour flickers, press C to adjust hour. (4)Press D the Date flickers, press C to adjust date. (5)Press D the month area flickers, press C for adjustment. (6)Press D the Day of Week area flickers, press C for adjustment. Then press B for recovering.
Nov 30, 2010 | Watches
Samsung LCD TV, no picture only sound
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
Sep 13, 2008 | Westinghouse LTV-30W2 Television
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Picture Flickers
there is a surface mount 9v regulator location # IC2925 i think. part # BA09FP that part is mostly likely the problem. it is located on the board right behind the video inputs. on the bottom right corner(looking at from back)
Feb 21, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Picture flicker
You can get info at ctechnicians.com
Dec 22, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Maxent MX42X3 42 in. HD-Ready Plasma Television Logo
2,921 people viewed this question
Top Maxent Televison & Video Experts
CoppellTVRepair.com
Jerry Greenberg
Jerry Greenberg
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
