No, phones don't have an infra-red transmitter. That would only work if the HK was connected to wifi and HK made an app and the internal circuity and logic to accept it.
Buy Harman Kardon DPR 1001 Digital Receiver (Discontinued by ... The receiver comes with Harman Kardon's programmed LCD remote control with EzSet ... I was planning to replace the speakers too, but now I'm having second thoughts!!
... 1001 Remote. Leave it to Harman Kardon to develop a groundbreaking full digital path receiver. ... Harman Kardon DPR 1001 owner's manual. MFR #DPR ...
It seems that one (or both) of the power amps are defective. To have a quick check, take a meter, sett it on the DC voltage and measure the outputs, one by one (with no speaker attached and no signal) for the short time when the unit stays on. If you have high DC voltage on the outputs (one or both) this means that channel(s) needs repairs (most likely the power transistors are blown). If one of the paired transistors is gone you need to replace both of them anyway. Good lock Kostiko
the problem of the continuos blowing of fuse internally is as a result of a defected component on the pcb board of the recevier .
you can do this by removing the cover of the recevier and check for the power transistor , power capacitor, if is defected with the use of a multimeter, replace for a new one of the same number
If the display does not turn on, then you have a power problem. The unit is not completely turning on. Since you opened up the unit, give it a sniff test to see if there is any burnt odor inside the unit. Check the fuses also. Have a look at the transformer board. It may have several fusible resistors sitting high on the board. If they burn open, there is no power to the display/cpu board.
I'm having the same problem only difference is I baugh my product new, i love my reciver when it works I'm convinced the product is built like everything else these days cheap with no pride, designed to malfunction so hard working Americans like myself pull out of pocket to replace the product being a different brand or what, cuz large corporations repeatedly screw the little man time and time again for years and believe me folks it's only gonna get worse if the little man sits back and does nothing.. I personally do NOT recommend this product costumer service with this product also burns my as# it's a waste of time on your behalf.. Thanks for reading hope to hear from many of you.
