The most important part of the compression test result is how even the cylinders are. That is, the lowest cylinder should be at least 80% of the highest. So if the highest was 120 lbs, as long as the lowest is 96 lbs or more, the compression is OK.
The ATT switch will give you more or less volume, depending on your mixer. I start out with it ON and if volume is low, put it OFF.
The 80 Hz switch is for rolling off the Sub Bass frequencies, use it if your source is Voice or Flute or such to avoid wind or breath noise. Enjoy...
Very common problem with today's receivers. Receivers made today don't have a true preamp section in the amplifier and do not amplify the sound to the extent of an older receiver. I have large 15" front speakers on my system, and have stuck with my 15 year old receiver just because I know that a new receiver will not have the power to drive them well. Many of the newer receivers need to be turned up to 50-60% before you can even hear anything from the speakers.
I think I had the same problem. This is how I fixed it.
I have my vizio 42 hooked up to a Harmon Kardon surround sound, and the digital cable box. Essentially, I can adjust the volume 3 ways - through the tv, cable box or av receiver. The humming sound happens when you have the volume maxed out on the av receiver and not the cable box.
For example, the sound level on my Harmon Kardon goes from -10 (lowest) to 10 (loudest), with 0 being the middle ground. The buzzing was happening when the Harmon Kardon was set to 10, and I was using the cable box volume to adjust the sound. To fix it, I turned down the volume on my receiver to 0, which may be about 50% max volume of the receiver. Then, I switched devices and used the volume on my cable box. This got rid of the static I was getting. Hope that helps.
i had the same problem for arround 3 months. almost a month after i bought the phone -- this is really really anoying. what i did was to clean all the messages i had in the memory. it worked out. i don;t know if it will work for you but try. also try reseting the phone. i did the same and it helped.
