When i turn my HK 3380 on, the on/off button goes blue but the amplifier doesn`t turn on???
If the display does not turn on, then you have a power problem. The unit is not completely turning on. Since you opened up the unit, give it a sniff test to see if there is any burnt odor inside the unit. Check the fuses also. Have a look at the transformer board. It may have several fusible resistors sitting high on the board. If they burn open, there is no power to the display/cpu board.
Posted on Mar 22, 2010
no the display doesn`t light up at all, it`s just the on/off button....and the relay does not click in...
the amplifier is only 2-3 years old, but i`ve opened it and there is not one sign of dust or dirt...
Has anything inside been cleaned since you obtained this -- like last century?
I say this with the certainty that dust and particulate matter can cause a host of problems from receive gang units to switches and the like.
If you are handy, you can:
1) unplug the unit.
2) unscrew cowl/cover
3) remove cowl/cover
4) Look in area where switch is. Is there dirt? Dust?
4.1) If yes, use old clean (paint) brush and vaccum to clean.
OK?
Good luck.
Alan Kelly AlanKinnA VerbatimIT
Does the display light up? Try other inputs? Is the speaker output set right? Can you run a test tone? Do you hear the speaker relay click a few seconds after turn on?
