20 Most Recent Harman Kardon Harmon Kardon SoundStick II Speaker System Computer Speakers Questions & Answers
Harman Kardon 06941V. Can I get the schematic diagram please?
Question edited for clarity. Question moved to a Harmon Kardon category. Doesn't see to be available online although some are. This is the best site https://thecodemachine.co.uk/Schematics/Search.php?manuf=Harmon%20Kardon https://www.google.com/search?q=harman+kardon+06941V+schematic+diagram Try contacting their support direct https://ca.harmankardon.com/support-knowledgebase.html ..
8/26/2022 2:37:08 AM • Harman Kardon... • Answered on Aug 26, 2022
3answers
Volume up button on my HK soundsticks III is not
289e1cb2-d245-4eab-973b-80c6355f1f04.jpgYou will need a 16volt dc PSU and a plug from Maplin for $1.49 PowerDin 3pin Plug Order Code: N83KT
1/10/2021 5:59:06 PM • Harman Kardon... • Answered on Jan 10, 2021
3answers
Taking apart harman/kardon subwoofer
turn the sub upsidedown, carefully remove the clear rubber feet (these are a dome fitted over a mushroom top), using the toothed gripper cutout of a pair of pliers (when closed it is the eye shaped opening visible on one side), grip the mushroom firmly but not so hard as to crush the mushroom and gently ease clockwise and anticlockwise (the mushroom is at one end of a clear plug blocking access to the four screws that hold the two parts together.
Be carefull to use the correct size screwdriver so as not to damage the screw heads as they are tight.
On reassembly, you may need to use glue to replace the rubber feet if the mushroom becames damages during removal.
12/7/2018 11:15:42 PM • Harman Kardon... • Answered on Dec 07, 2018
Is it possible to install aux 3,5 mm plugg?
Probably not, but you can buy a 3.5 mm.-to-RCA adapter cable to hook up a device with RCA (L/R) AUDIO OUT jacks (and no 3.5 mm. headphone jacks) to your Harman Kardon speakers which, I assume, have only 3.5 mm. LINE/AUX IN jacks (1 or 2).
12/30/2014 12:58:20 AM • Harman Kardon... • Answered on Dec 30, 2014
Where can have sound sticks repaired?
The best if To take them on official repair shop you pay a litle bit if they arent in warranty but i worth you will have a new product Harman Kardon US
12/28/2014 8:50:23 PM • Harman Kardon... • Answered on Dec 28, 2014
2answers
Harmon/Kardon SoundSticks 2, Power adapter?
If you go to the Harmon/Kardon website, you can find where to buy replacement parts.
http://www.harmankardon.com/
Select product support on the front page, then go to parts.
Then select your product as Harmaron/Kardon SoundsticksII and select your country.
Hope this helps,
Nathan.
11/4/2014 7:23:15 PM • Harman Kardon... • Answered on Nov 04, 2014
2answers
Hi, how can I open up the 2 halves of the Harman
Joewosh, did you ever get this fixed? I have the same problem now and trying to find a solution. Thx!
10/19/2014 2:29:27 PM • Harman Kardon... • Answered on Oct 19, 2014
0answers
0answers
0answers
0answers
0answers
Volume on my soundsticks fro HK not working
Check its speakers.
5/2/2012 2:37:53 AM • Harman Kardon... • Answered on May 02, 2012
Harman Kardon Harmon Kardon SoundStick II Speaker System Computer Speakers Logo
100 questions posted
Top Harman Kardon Audio Players & Recorders Experts
 Grubhead
Grubhead
Ngoro
SmartAviator
SmartAviator
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Harman Kardon Audio Players & Recorders
Most Popular Question
1997 jaguar xk8 need radio code
  • Audio Players & Recorders
