Compaq FP 7317 17" LCD Monitor Logo
Posted on Aug 22, 2011
On screen "OSD Locked"
OSD LOCKED.
OSD probably refers to on screen display. and since the error message specifically states Windows XP you can eliminate anything that is not running Windows XP as the OS so likely suspect is #1.
Hand-me-down N2750W
On screen display is locked. Fix it by:
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
1helpful
My computer says OSD locked , ive tryied every thing and nothing worked , HELP!!!!!!!!!! PLEASE
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD. Source(s): http://h10025.www1.hp.com/ewfrf/wc/docum...
2helpful
Flatron W1942TQ monitor has "OSD Locked" message
Press and hold menu button for a few seconds, pressing and holding, acts as a toggle. So if OSD LOCKED still appears, pressing again UNLOCKS.
1helpful
I get OSD locked and cannot change the screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock is displayed. If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
Jan 26, 2011 • AOC Monitor
1helpful
"OSD Locked" message appears when
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds. If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
1helpful
My monitor is of AOC " e2043Fsk " . When I try
7helpful
"OSD LOCKED" box on my screen
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
3helpful
Osd locked , keeps flashing on screen
hi
vote me if you have your solution
1helpful
My computer screen has a blue box that pops up and say "Controls locked". I am assuming that the buttons on the bottom right hand corner of my moniter is what it is talking about because when I hit the...
This is from the user manual for the monitor. You can download a copy from hp here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=324216&os=228&lang=en&
Click on the "monitor user's guide" link to download.
There are four adjustable options on the OSD settings screen: Lock OSD settings, Timeout, H Position, and V Position.
To change OSD settings:
1 Open the OSD setting screen under the Advanced menu. See
“Using the On Screen Display” on page 25.
2 Press the Browse buttons to select the option you want to adjust.
3 Press the Select button to check the option.
To change OSD lock setting:
1 Press the Browse button to select yes (lock) or no (unlock). The
setting is automatically saved when you change the value.
2 Choose Exit sub-menu and press the Select button to return to
the OSD Main Menu or press the Menu button to exit OSD.
NOTE: Once OSD is locked, all OSD functions including the
shortcut buttons are disabled. If OSD is locked, pressing
any button on the monitor directly opens the Lock OSD
settings window so that you can unlock OSD.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
