just follow the steps below
1. Manually turn on the TV.
2.Press and hold the CODE SEARCH button until the
INDICATOR LIGHT lights, then release the CODE SEARCH button.
3.Press and release the TV button (The INDICATOR LIGHT will blink then remain lit).
4. Enter the code using the Number Buttons. After your code is entered, the INDICATOR LIGHT will turn off.
code list for philips :
003, 004, 008, 012, 019, 062,068, 069, 075, 076, 086, 087, 088
5. Aim the remote at your TV and press the ON•OFF button. Your TV should turn off.
6.With your TV on, press CH+. If the TV responds, no further programming is required.
if it works ignore the following thing (quite difficult and irritating one)1. Press and hold CODE SEARCH until the INDICATOR LIGHT lights, then release CODE SEARCH.
2. Press and release the device button for the device’s code you are retrieving (TV). The INDICATOR
LIGHT will blink once then remain lit.
3. Press and release CODE SEARCH. The INDICATOR LIGHT will turn off.
4. Starting with 0 on the keypad,
press the number buttons in
order (0-9) until the
INDICATOR LIGHT blinks.
5. The number which causes the INDICATOR LIGHT to blink is the first digit of your code.
6. Repeat step 4 until you have
retrieved all three numbers in code
if you want code list for all devices
download this pdf
