Question about RCA CRK76TE1 UNIVERSAL REMOTE - With Gemstar Guide Plus
Red Light Won't Stay On
I've looked up online directions and even the actual manual for this remote. My roommate got the TV to turn OFF ONCE with the remote by pressing some buttons with the play button but now we cannot get it to happen again. The directions are simple and say to hold the "TV" button along with the "on/off" button until red light stays on (but it doesn't) and press play which makes it flash 4 times while searching codes (this doesn't happen either). The other way it says, just hold the TV button and manually enter the codes, the red light will flash and turn off if correct or it'll flash 4 times if incorrect (every time we push any button (just one, it doesn't let us finish code) it flashes and turns off red light. Nothing seems to be working but I know it's possible cause it turned off once! HELP!
Posted by danielleb936 on
Atlas ocap
use the camera digital or cell cam and with the remote control viewn see if the LED are ON. see the photo attached.
If do not do it. Open the remote control clean the keypads from corrosion, and resolder any colder joint . clean the contacts batteries and try again.
May 30, 2013 | Televison & Video
Fujitsu plasmavision won't turn on
How many times do the red light blinks at a time? Count it. It is fault indication. After counting it, click here for details.
Dec 24, 2012 | Televison & Video
Won't stay on
3-blinks by the SONY TV error code indicates that there is an audio circuit problem, ether is a shorted audio amp IC on the main board, or the power supply that supply the power to the audio amp section is defective.
May 22, 2017 | Sony KDL-52EX701 52 in. LED TV
How to install RCA streaming media player on an old TV
I've had a quick look at some instructions online, can't be sure if I'm looking at the same device as you but.
Guesstimating, you're connecting via the composited A/V jack out from your box to RCA (red,yellow,white) inputs on your tv. Or the same but using a SCART converter.
If so, once you've turned it all on, you probably have to change to the correct AV input on your TV. Just keep pressing the AV button on your TV remote control, it should cycle through all the AV inputs until it gets to the one you require.
Apr 28, 2012 | Audio Players & Recorders
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
Red light comes on but power button won't turn it on
Please confirm actual brand and model as it is not clear what set you have
Mar 11, 2012 | Televison & Video
Won't charge. Red light come on for about 5mins then flashs red when i pull the trigger the red light comes on does not turn to green nothing works
Hi Peter,
I'm sorry to hear you're having difficulties with your DC16. From what you've described, it sounds as if the filter may not be correctly fitted - please follow the steps shown in our online support guide to resolve this:
http://www.dyson.co.uk/support/help.asp?article=1519&product=DC16-SY-STD
If you're still having issues after trying this, it's probably best if you get in touch with us directly, so one of our Helpline experts can run through some troubleshooting over the phone. You can call free on 0800 298 0298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Nov 01, 2011 | Dyson DC16 Root 6 Bagless Handheld...
My remote will not cut on my Bose Cinemate system. I have changed the batteries in my remote and the red light on the receiver is illuminated, so I know the system is operational, . I've also unplugged...
It seems to be a common misconception that the remote is necessary to turn a device on. All devices have hard-wired power controls. Does THAT work? It is unclear which device (remote or the Cinemate) is malfunctioning. If the Cinemate won't turn on by its own power switch the remote won't magically bypass whatever the problem is.
The Cinemate Manual offers some steps to take if it won't turn on, as well as other guidance.
Bose.com
Jul 31, 2011 | Audio Players & Recorders
Tv won't switch to "tv"
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
Jun 24, 2011 | Vizio 42 in. LCD TV
RCA CRK76TE1 UNIVERSAL REMOTE - With Gemstar Guide Plus Logo
759 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
