I was changing the channels with the remote where sudenly the TV stopped responding to the remote command, I tried to reprogram the remote it didn't work, then I ended up buying univesral remote still didn't work, is ther anything that I need to check on the TV itself that might solve the problem.
The IR Sensor at the front of my tv is not flashing. I have changed the batteries on the remote light is flashing aswell but its just not moving anything on tv..Please help
Sounds like a bad main control board!!!
Tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
