SOURCE: service code SC546 on a Ricoh Aficio 1045
Try to go into service mode to reset the code...
Clear yellow botton
7
then press and hold the red stop botton till the display changes and
then turn the main Power switch Off then back ON... You do not have to
do any thing in service mode, just get to that display.... Don't change
anything unless you know what you are doing. sc546 has to do with the
fixing unit. You may be able to reset it.
This is usually caused by the fuser not reaching the correct temperature in which case you would need to get it repaired.
