Hi there i change eprom 2045 with other machine when i switch on it show 000000 counter but before fixing it was 450093 .plz tell me how i can fix the problem
hi dear befor i asked u plz tell me when i fix the printer in ricoh 2045 then its give 990 with out printer its ok what i should do.hi dear befor i asked u plz tell me when i fix the printer in ricoh 2045 then its give 990 with out printer its ok what i should do.
dear sir i have problem in ricoh 2045 its give the sc 990 after making coppy may be software problem but i have not software for this machine how i can repair this machine with out change or update software replay medear sir i have problem in ricoh 2045 its give the sc 990 after making coppy may be software problem but i have not software for this machine how i can repair this machine with out change or update software replay me
Re: ricoh 2045 sc 990 when i fix printer its appear
Did the donner copier have a finisher on it? The code means a miss comunication with the finisher. There is a HD that is used with a finisher. The meter count can not be changed that I know of......The reason it shows 000000 is that the battery was disconnected from the eprom.
Hi
I have found this explanation of the error message:- Description:Software performance error
The software attempted to perform an unexpected operation. Causes:• Software defective • Internal parameter incorrect • Insufficient working memory • When this SC occurs, the file name, address, and data will be stored in NVRAM. This information can be checked by using SP7-403. Note the above data and the situation in which this SC occurs. Then report the data and conditions to your technical control center.
This can be confirmed here: Error Codes Ricoh Aficio 2022 Code 990
and also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
SC 990 is software performance error. This means The software attempted to perform an unexpected operation. Possible causes: 1. Software defective 2.Internal parameter incorrect 3.Insufficient working memory 4.When SC occurs, the file name, address and data will be stored in NV RAM this information can be checked by using SP 7403. Note the above data and situation in which this SC occurs. Then report the data and conditions to your technical control center.
if you are getting the sc990 code, you will need to have someone come out and do preventative maintenance (PM) on the machine. the 990 code has to do with the drum quality, and the only way to fix it is to, at least, have the drum unit rebulit.
SC 990 is a software error. It usually can be cleared by turning the machine off and back on. It occurs when the internal program gets locked up. Sometimes it requires a firmware reload, other times it maybe an indication that your hard drive is on its way out. The best thing I can say, is lets hope it just happened, and will not again!
thanks for helping
