20 Most Recent
Western Digital Hard Drive Questions & Answers
Drive is recognized correctly in
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,((IDE,SATA
the leads)) from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
I have connected my 300 gb sata hdd to my pc
They don't have master/slave settings as only one SATA drive can connect to a controller, however some BIOS have a setting designed to facilitate older OS's like XP that don't always have drivers available for the newer SATA RAID controllers built into most mid to high end PC's. If this setting is enabled on your PC then they would look to windows like a pair of master IDE drives on a Primary and Secondary IDE Channel even though each has it's own dedicated controller.
My second not show in my computer
It is a desktop unit I supposed?
Hello, first of all do you change your motherboard with the same type? If not, and you used the same hard drive with the software installed intact. There will be software configuration conflict, since it is a different mobo, different chipset and different driver to run it.
Including the video card. My suggestion will be a fresh installation of the software. It lessen software-driver conflict and is direct configuration to your new set up. This can also a hardware ID conflict.
I ;have formatted the WD external drive and
You should not even try to install an operating system on an external drive. Windows looks at the "C" drive and installs programs to "C" drive. You are trying to put it on the "G" drive. You will have too many problems and wish you never had tried. Buy a larger main drive and partition it with two equal partitions. Then "Dual Boot". You will find how to do this on the internet. Just Google "Dual Booting".
Sir,
I have a Lenovo laptop.
If your HARD DRIVE was exposed to a magnetic field, this can happen.
Try a scandisck run.
Boot up in safe mode and run fix disk.
Cannot format my WD 1TB external hard drive
The hard disk is having bad sectors on its first 3000 sectors.the bad sectors are caused by degradation of the platter of the hard disk.OR the factory area of the hard disk has certain files called SMART, G -LIST and other log files.Unless one empties those log files with a good tool , one cant format ones hard disk.
Not detecting, beeping
This is likely a couple problems;
1. The hard drive is dying or is dead. You're looking at hardware recovery if this is the case. There are some tools such as Spinrite that might be able to recover the disk. (
GRCHard drive data recovery software)
2. The power supply on the computer/laptop is not functioning as well as it used to. Try using another PC to see if there's any difference in results.
Western digital 2tb my passport keeps flashing; not detected
Remove the drive from the external case it is in and connect directly to your computer - see if the bios recognizes it. If so, the OS will do so also and you can access it. Also means the electronics of the external case are no good. If not recognized in other machine, the hard drive has gone to hard drive heaven and needs to be replaced.
