20 Most Recent
HP PhotoSmart 420 InkJet Printer Questions & Answers
When I insert my SD memory card into my photosmart
Hi there
I dont think your printrt is made to read SD cards the only way it see the SD cards if they are in the camera and the camera lead into the USB inlet on the printer.
Printer Specifications
Category Specifications
Connectivity USB 2.0 full-speed
PictBridge: Using the front camera port
Bluetooth: Microsoft Windows XP Home and
XP Professional
Image File Formats JPEG Baseline
Margins Top 0.0 mm (0.0 inch) ; Bottom 0.0 mm (0.0 inch);
Left/right 0.0 mm (0.0 inch)
Media Sizes Photo paper 10 x 15 cm (4 x 6 inch)
HP
C1AB0001 ERROR IN HP 8038 PRINTER
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
