20 Most Recent
Xerox WorkCenter PE120i All-In-One Laser Printer Questions & Answers
My Xerox Workcentre PE120i screen
This is a fairly common problem with most printers. It is generally caused by something confusing the sensor that detects the paper.
1) Remove all the paper from the printer.
2) Switch off the printer and unplug from the mains for 30-45 seconds
3) Switch printer on
4) Put in paper
5) Try and print!
Most of the time this will cause the printer to "reset" itself and should print fine.
Regards,
sjstore2
Xerox WorkCentre PE120i - Paper Jam 1
Normal
0
I suggest you get a sheet of Card Stock (Heavy
paper) and place it in the feed way. Then press the print
button applying a slight amount of pressure on the Card Stock so it
will feed through the printer. The reason for this is in some cases I
have been able to clear the paper track of debris that was deposited there
over time.
Worth a try, as I have fixed a number of printers this
way, saving costly repairs.
Hope this helps.
Bud
Need drivers for Windows 7
A Windows 7 driver is not available, but you may find that the Vista driver works OK. You can get it here:
http://www.support.xerox.com/support/workcentre-pe120-pe120i/downloads/enus.html?operatingSystem=winvista&fileLanguage=en
Low heat error
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Una xerox 120i k me
Assuming you have the correct consumable for your printer/contract. Make sure you remove any plastic or stickers near the cartridge.
You can also follow this
tips. Page 2.5
Reboot the machine removing the power cord.
