20 Most Recent
Teac MP-111 MP3 Player Questions & Answers
I need a mp3 software for taec mp3 player
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer. You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
RCA Pearl TH1602 Frozen?
I had the same problem, usually plugging it into the usb port on the pc and verifying the files on the player, then disconnecting the player will solve the problem. Other times i have to reformat the player, if you do that, you will have to put all your music back on. It's a pain, this has happened to me 4 times, I've only had this thing less than 6 months! It was inexpensive, I guess you get what you pay for, but I like having a AAA battery instead of having to remember to plug it in to the pc to recharge every 15 hrs.
Hello, my mp3 player starts
The problem has nothing to do with the battery nor the memory. The problem here is the program itself. You need to re-flash the FIRMWARE of the device. Here's what you need to do: 1. Know the default firmware version of the MP3. Check the user manual or the CD that came with it (if there's a CD). 2. If your MP3 came with a CD, check if the CD if it has the firmware that you could use and install it to your MP3. The instructions should be in the manual. 3. If the CD does not carry the firmware, contact the manufacturer and have them do it for you. I'm hoping that the device is still under the warranty. Having the firmware installed in your device should not cost you too much if the device is out of warranty. Have a great day!
Not starting
you cant format a mp3 player it deletes all of the system start up memory. the only fix is to buy a new one.
sorry!!
I have an RCA Peal
When you download your Audible audiobook, it should also download a program called AudibleManager. While in AudibleManager, play your audiobook. When you do so, it should ask you to log in using your Audible name and password. After you do this (you don't have to listen to the whole thing), you should be able to upload it to your device with no license problems.
Teac mp111
You should press the "Menu" button (two seconds) -> in the screen there will be message "Play Music" confirm this message by pressing "Menu" button again. Please enjoy your music!!!!
TEAC MP111
If one of the files you uploaded has a different format (e.g. OGG), or a name with special characters,... the MP3 player will FREEZE.
Connect the device to your computer (USB port), remove the unrecognized files, unmount properly, empty the trash while unmounting.
It should work again.
So, when you upload additional files, do it gradualy. It will be easyer to identify the faulty...
Have fun, good luck
LRC? does anybody see lyrics?
I dont see an obvious problem. Got to http://lrclyrics.50webs.com and go through the "How to use" section and see if you are doing the same thing.
