20 Most Recent Teac CD-RW880 CD Player / Recorder Questions & Answers
2answers
I have a stanton c324 and it wont eject the cd's
get a butter knife and pry it open
6/13/2014 5:24:36 PM • Teac CD-RW880 CD... • Answered on Jun 13, 2014
How can I connect my CD-RW880 recorder to the
Make sure the phonograph is connected to the Phono Connectors. Hook up your CD recorder to the tape. The play connectors on the CD recorders can connect to the tape play connectors on your stereo. The record connectors on your CD recorder connect to the record outputs on the tape connectors on your stereo. You can also connect you CD recorder to the VCR connectors if you are using an audio tape as your source. All of the outputs and inputs are the same level except the phono.
1/23/2013 5:50:06 PM • Teac CD-RW880 CD... • Answered on Jan 23, 2013
Need to order blank Cds
You have to buy 700Mb CD-R. One of the best brand would be Sony or TDK. You can buy by clicking on the link below. http://www.amazon.com/Digital-Recordable-Recorders-Computer-Assorted/dp/B003429IWC/ref=sr_1_3?ie=UTF8&qid=1314027313&sr=8-3
8/22/2011 3:36:50 PM • Teac CD-RW880 CD... • Answered on Aug 22, 2011
My Teac CD-RW 880 CANNOT
DIN in this context stands for Digital IN. It'strying to tell you that it can't see a good digital signal from the source.
See page 16 and 23...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Teac-CD-RW880-CD-Players-manual/id/3875dj898/t/2/
4/6/2011 9:47:44 PM • Teac CD-RW880 CD... • Answered on Apr 06, 2011
How do I see the
Go to http://www.manualnguide.com/download/manual-guide/teac-cd-rw880-cd-recorder-owners-manual.html and download the manual. You need a PDF reader
1/29/2011 11:29:16 PM • Teac CD-RW880 CD... • Answered on Jan 29, 2011
3answers
CD-RW880 records only 10-15 minutes then stops
Hi i would say try other cd recordable media but it sounds like your player has a tracking/laser pick-up problem or a laser mechanism fault,i would suggest you take it to the nearest repair agent to get them to look at it for you. regards. paul.
12/17/2010 4:12:45 PM • Teac CD-RW880 CD... • Answered on Dec 17, 2010
When I try to record, I get a red siganal that
it might be copyrite risticted
11/8/2010 6:10:40 PM • Teac CD-RW880 CD... • Answered on Nov 08, 2010
After i finalize disc, I
you might have a bad input on your reciever --the audio might be ok ---change your patchcord inputs to another onr i.e aux tv etc..
9/3/2010 7:08:59 PM • Teac CD-RW880 CD... • Answered on Sep 03, 2010
DIN UNLOCK on the display
The CD isn't reading the disk, so it reports "blank disk". It could be as simple as the CD laser lens having dust or lint on it, in which case you can use a CD cleaner disk (available at Walmart or Radio Shack, Best Buy, etc.). If that doesn't help, the second most common problem is that the laser lens is out of adjustment, and not focusing properly, thus not reading the CD. This can happen with slight wearing of mechanical parts, or any change in the detection circuity (aging of capacitors, etc.) This can be corrected, but it entails taking the unit apart and adjusting the CD lens on a trial and error basis (adjusting, then trying, until you get it right). Here's a web blog on the procedure, and it will clue you in on what you can try. If you don't feel like tackling it yourself, of course, you will have to have the unit serviced. Get an estimate first, since it's also possible that they will just replace parts, or possibly a circuit board, in the event that adjustment of the lens doesn't solve the problem. Here's the blog:
http://www.fixya.com/support/r4192169-fix_calibration_cd_dvd_drive_no_disc
Good luck, and hope this helps!
7/22/2010 3:39:04 PM • Teac CD-RW880 CD... • Answered on Jul 22, 2010
I.m having a problem with hum and interference
Instead of flailing, let's narrow it down to a specific signal path. Can you describe hum and intererence? Make sure no analog cabling is routed near power cords or strong magnetic fields.
Describe the conditions when it happens - Analog Record? Analog Playback? Digital Record or Playback?
What other equipment is involved? Do you have track lights?
5/17/2010 11:23:59 PM • Teac CD-RW880 CD... • Answered on May 17, 2010
Read error
Some recorders, especially Phillips REQUIRE using the "Music" CD's. It was a lame attempt at copyrright enforcement.
12/15/2009 3:14:41 AM • Teac CD-RW880 CD... • Answered on Dec 15, 2009
Won't record
Are you using CD-R- Audio or Music discs? It won't record onto computer (data) discs)
11/9/2009 6:16:18 PM • Teac CD-RW880 CD... • Answered on Nov 09, 2009
2answers
Question
I am 99% certain that it will only work with 'audio' discs. This is the case with my Philips CDR-796 and as far as I am aware applies to all consumer CD recorders.
Hope this helps
HifiJohn
10/14/2009 1:32:08 AM • Teac CD-RW880 CD... • Answered on Oct 14, 2009
My Computer isn't reading a Phillips CD-R
Did you "finalize" the CD-R on your Phillips CD-R audio recorder? You must finalize it for it to find the Table Of Contents. Can you read it in your Phillips recorder? Try to finalize it again. I also have heat issues with the Phillips recorder, and I added a small computer fan to it to prevent lockups. Best wishes,
10/10/2009 2:46:43 AM • Teac CD-RW880 CD... • Answered on Oct 10, 2009
My unit will not record cd-rw audio discs.
cd-rw is an unprotected format.. I doubt it WILL copy..
the cd-r is seen as a normal cd now.. the "ReWritable" isn't meant for "pirating" ;)
9/3/2009 8:20:34 PM • Teac CD-RW880 CD... • Answered on Sep 03, 2009
Teac CD-RW880 CD Player / Recorder Logo
Popular Tags
47 questions posted
Popular Products
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Teac Audio Players & Recorders
Most Popular Question
discs will not eject unit makes strange
  • Audio Players & Recorders
