20 Most Recent
Fujifilm FinePix AX550 Digital Camera Questions & Answers
Lens won't open
If there is a creaking noise when it is opening and closing .. it must be some dust or particles which is preventing the movement of the lens .. It can also be the problem with the circuit itself.
Things to do :
1. try to use air to clean in and around the lens.. mainly withing the attachment contacts.
2.invert the lens facing ground and gently tab from above .. with blowing air in the junctions which will remove the particles within.
3.If the lens had been mishandles and there is a wear in the threads the lens need replacement of the parts involved in its movement.
4.If there is a misplaced lever or parts , it needs servicing ..
Always be very careful with the lens.. the parts are pretty delicate and can harm your unit if wrongly handled.
How to put date & time stamp on photos ax550
The date and time (and a lot more) are stored with each picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Date stamp
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Fujifilm ax550 driver downlod
Do you really need a driver?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Ax550 won't take picture, shooting mode icon outlined in red.
you can try to format the memory card and then reinsert it to your camera again to try.Check whether your camera is focusing or not. unless it focuses and its locked , the shutter wont get released. it can be due to improper light or distance of the object, or even problem with your camera internally.check if there is any noise while focusing,a jam can also cause such a result for some cameras.
Set date and time on fujifilm ax550
Press the MENU/OK button, press cursor-left, use cursor-up/down to select the wrench icon, press cursor-right, then select the "Date/Time" command.If you need a manual, you may download a copy
here. The setup menu instructions are on page 65, the date/time setting instructions are on page 13.
In my fuji frontier 370 error 2503 and w2411 is coming
The "W" indicates that it is a recoverable error. The "24" indicates that there is a problem in the paper feeder. The "25" indicates that it is a laser printer problem. Looks to me as though you have a paper jam.
2/13/2024 7:57:44 AM •
Fuji Cameras
Answered
on Feb 13, 2024
Sensitive Command Dial on Selector Button.- S9800 Finepix - any ideas what's wrong?
If the command dial on your Fuji Finepix S9800 camera is overly sensitive, making it difficult to select items on the menu or adjust settings, there are a few steps you can try to address the issue:
- Clean the dial: Sometimes, dirt or debris can accumulate around the command dial, affecting its sensitivity. Use a soft, lint-free cloth or a small brush to gently clean the area around the dial, removing any particles that may be causing the sensitivity issue.
- Adjust the sensitivity settings: Check the camera's menu or settings to see if there are any options to adjust the sensitivity of the command dial. Look for settings related to "dial sensitivity" or "control dial response" and experiment with different levels to find the one that suits your preferences.
- Reset the camera settings: If the sensitivity issue persists, you can try resetting the camera settings to their default values. Look for the "Reset" or "Factory Reset" option in the camera's menu and choose the appropriate setting. This will restore the original settings and may help resolve any software-related issues.
- Contact customer support: If none of the above steps resolve the sensitivity problem with the command dial, it may be worth contacting Fuji customer support for further assistance. They can provide specific troubleshooting steps or advise you on whether the camera needs to be inspected or repaired by a professional technician.
It's important to handle the camera with care while attempting any adjustments or cleaning. If you are unsure or uncomfortable with the process, it's recommended to seek professional help or take the camera to an authorized service center to avoid any potential damage.
6/18/2023 4:43:48 PM •
Fuji Cameras
Answered
on Jun 18, 2023
