20 Most Recent Dual XDVD8170 Car DVD Player Questions & Answers
2answers
Open but screen will not come all the way up?
problem with the screen thats a recall take it back malfunction with the product
11/4/2014 6:02:30 PM • Dual XDVD8170... • Answered on Nov 04, 2014
2answers
I bought a xdvd700 off of Craigslist and it did
The only wires that must be connected to power up are Red(Ignition) Yellow (memory) and Black (Ground) The red and yellow can be ran directly off of the battery for testing purposes. It's not uncommon to have an extra wire or two when wiring a stereo.
Good Luck - Hope you got a stereo that works.
8/7/2011 10:10:36 PM • Dual XDVD8170... • Answered on Aug 07, 2011
I have the xdvd710 when
The dual XDDVD710 RADIO has a volume memmory (it seems), it will go to the last volume setting that it was set to, not play to,(supposly to keep it from blasting you when you turn it on and you forgat u had the volume on blast).
To set it,
1 turn radio on,
2 turn the volume to desire Level you whant it to go when you turn it on (other Levels besside BLAST hopefully) ,
3 push the volume button in, that should do it.
Now you can play your music loud and should you forget that you had it on BLAST (to over come road noise) when you last played your radio, it should start at the preset volume.
2/15/2011 7:40:38 PM • Dual XDVD8170... • Answered on Feb 15, 2011
Screen wont come all the way out
reset the system
11/30/2010 9:46:38 AM • Dual XDVD8170... • Answered on Nov 30, 2010
How do i find out which one is the power wire
on the head unit its yellow. if you need to know n your vehicle send me year make and model
8/25/2010 3:23:44 AM • Dual XDVD8170... • Answered on Aug 25, 2010
I have a dual xdvd700 wires got pulled out of
are you still working on this issue or did u figure it out?
thanks
6/9/2010 5:25:59 PM • Dual XDVD8170... • Answered on Jun 09, 2010
4answers
E- brake by-pass code
This is the best bypass method for the Dual XDVD8181. Althoug i am not sure if it works for any of the similar models b Dual. My guess it will.
1) Groun the emergency brake wire.I used the radios black groud wire.
2) Insert a DVD and let it play until you hear the sound.Copied DVDS will not work for this.
3) Press STOP on the remote TWICE.
4) Using the remote enter 26604 and press enter .If done correctly you should hear it beep and the video will be viewable.Good Luck.
0
5/18/2010 1:05:05 AM • Dual XDVD8170... • Answered on May 18, 2010
Turns on but nothing displays.
it sound like the memory wire is hook up wrong, check the yellow wire first then the red wire if still the same problem, connect the red and the yellow wire together to see if it come on it should come on you might have to run a hot wire from the battery in the dash then hook the yellow wire to it so your memory stays on
12/15/2009 11:07:32 PM • Dual XDVD8170... • Answered on Dec 15, 2009
Dual xdvd 8625 double din emergency brake bypass
you can ground it,then enter the code 26604 after u insert a dvd real dvd then press stop twice then enter the code it should work
12/15/2009 11:01:33 PM • Dual XDVD8170... • Answered on Dec 15, 2009
How to bypass a dual xdvd710 without the remote
ground the brake wire from the radio to a switch that cut off and on, to the chassis ground you will have to hit the switch every time you want to watch the tv the switch acts like its hook up to the parking brake so when u hit it twice it thinks that the brake is engage
12/15/2009 10:53:27 PM • Dual XDVD8170... • Answered on Dec 15, 2009
on the 9101 the enter button is ok make sure you use a real dvd no bootleg
12/15/2009 10:35:39 PM • Dual XDVD8170... • Answered on Dec 15, 2009
I BOUGHT THE DUAL DVD
first thing you can do is mail the senior executive superviser at dual on this id: [email protected]
or go to the dual official website and find the nerest local dual delear and sort out the matter. dual website is: http://www.dualav.com/about/contact.php
also for other information you can talk to them on: 1-866-382-5476
thanks for using fixya.keep updated. please do not forget to accept and rate this solution.
6/22/2009 1:37:27 AM • Dual XDVD8170... • Answered on Jun 22, 2009
2answers
Xdvd710 manual
1/30/2009 7:47:17 PM • Dual XDVD8170... • Answered on Jan 30, 2009
Xdvd8181 not accepting any discs
Check this.
http://www.fixya.com/support/t892341-cd_wont_stay_in
8/30/2008 9:14:48 PM • Dual XDVD8170... • Answered on Aug 30, 2008
Subwoofers?
You can customize your subwoofers to fit anywhere in a vehicle but the science to getting your subwoofers to do its job is in the box. If you are trying to save space, theres plenty of boxes customized to get that science in your car and save you space. Or rid the idea of having a box and installing some updated 6x9's that'll do the job for ya at saving space and giving you the bass effect you want to hear as well..
good luck!
7/8/2008 4:05:01 AM • Dual XDVD8170... • Answered on Jul 08, 2008
RADIO
The only thing is replacing the PLL IC in the tuner circuit. It is failing when it gets hot.
Your best bet is a service center.
7/1/2008 1:08:50 AM • Dual XDVD8170... • Answered on Jul 01, 2008
Hoowww
You need to put it on a switch that goes to ground in one position and in the other position it needs nothing connected. Then you flip the switch to ground it when you what to watch the video
7/1/2008 1:07:34 AM • Dual XDVD8170... • Answered on Jul 01, 2008
When upgrading an existing single tone car horn to a dual tone how complicated is the extra wiring?
No Simon, that won't work. What you are suggesting is wiring the two horns in series, and that halves the voltage so you would have two horns running on 6 volts. They need to be wired in parallel. A lot depends on how good the horn's relay is and if it can handle the load of two horns. My thought is that it probably will as many vehicles already have twin horns. The positive lead from the relay needs to split and go to the positive sides of both horn, and the negative of the horns to grounds. Ideally, two relays, two horns, two grounds. Look at the YouTube video of the guy that added a huge locomotive twin air horn. It is funny as he goes looking for jay walkers! If I remember he had to install a second battery for it as the load for the air compressor, made the engine stall. ..
4/18/2024 5:40:17 PM • Dual Car Audio &... • Answered on Apr 18, 2024
Dual XDVD8170 Car DVD Player Logo
Popular Tags
28 questions posted
Top Dual Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Dual Car Audio & Video
Most Popular Question
e brake pass code
  • Car Audio & Video
