20 Most Recent Sharp Aquos LC-20B6U/LC-20B6E 20 in. HDTV-Ready LCD Television Questions & Answers
Aquos LC-20B6E fails to turn on sometimes.
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size. Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
7/13/2017 4:16:18 PM • Sharp Aquos... • Answered on Jul 13, 2017
0answers
Fuse in aquos
Be the first to answer 8/25/2013 5:00:41 AM • Sharp Aquos... • Posted on Aug 25, 2013Be the first to answer
Need base table mount for sharp Aquos LC-20B6U
Check out tvpartsguy.com ive bought the same stand from them recentlly
2/12/2013 9:40:49 PM • Sharp Aquos... • Answered on Feb 12, 2013
Varous tv channels do not have sound. It is NOT a
TO: rdh041: I don't have the solution to you problem, but we have the exact same problem with our Sharp AQUOS 20" LC tv. Different model than yours, but same age and same perplexing issue. Several channels suddenly have no sound. If you've found a solution, would you please post it? I'll do the same. Thanks.
7/25/2010 3:00:57 AM • Sharp Aquos... • Answered on Jul 25, 2010
2answers
SHARP AQUOS LC-60E78UN 60 inch LCD TV. Are there any firmware updates please?
Question edited for a lot more clarity! All questions need full 'make model (what it is)' please.Question moved to Sharp Aquos category.This is their support page which is pretty bad. There is an email link. You don't say WHY you want a firmware update, but firmware in not supplied for televisions according to our Fixya television expert Larry. Firmware updating is fraught with danger and should not be undertaken lightly even when it is available. Sharp only supply software updates, no firmware.https://www.sharpusa.com/Support/ProductDetail.aspx?model=LC-60E78UNSOFTWARE updates are here in the manual on this page and continues in detail on the next page.https://www.manualslib.com/manual/318507/Sharp-Aquos-Lc-60e78un.html?page=24..
11/25/2023 11:10:39 PM • Sharp Aquos... • Answered on Nov 25, 2023
2answers
Hi. I have a logo banner on the top left of my screen I can't figure out how to remove.
Go to Menu select function or Service and checked auto demo is on. If it is on make it OFF
11/11/2022 10:37:31 PM • Sharp Aquos... • Answered on Nov 11, 2022
2answers
Sharp TV LC60LE745U the screen remained black and an arrow on the bottom of the TV stay blinking
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience.
10/8/2022 10:22:49 AM • Sharp Aquos... • Answered on Oct 08, 2022
Can I transfer the data stored in my TV to my USB?
No, you just told the television to format the USB into its own formatting format. It doesn't back it up for you. You should have purposely made a back up of everything on the USB memory stick to your computer. If you haven't done that, you can put the USB stick into the computer and use 'Undelete' software. Recuva is pretty good and the ones that normally say 'Free', mean they are free to see what is can find, but not to restore is back. https://www.google.com/search?q=%27Undelete%27+software Recuva https://www.ccleaner.com/recuva Everyone should have CCleaner! ..
3/12/2022 7:57:21 PM • Sharp Aquos... • Answered on Mar 12, 2022
Program a sharp aquos remote to control a samsung bluray dvd player
Not sure you can
12/22/2021 5:58:07 PM • Sharp Aquos... • Answered on Dec 22, 2021
Scanned Channels not saving on my Sharp AQUOS 32 LE185M LED TV.
https://elektrotanya.com/cgi-bin/download2.cgi?dk=wgzgtxz9xfakb6w5s2gbjalr7l6hmh579r0th7lfiongeyjc&fid=105643&file=sharp_aquos_lc32_40_46_52le700un.pdf Should be the faulty memory IC. Download its service manual by the above link, and refer it. If you wish to get some details; check the sites linked here. https://elektrotricks.blogspot.com/ https://electronicshelponline.blogspot.com/ Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault. Search the site by type in the Brand Name of your set, in its search bar at the right side column, and press enter. See it in by Webview with mobile or by desktop. Mobile View has no search box. Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
10/16/2021 6:51:04 AM • Sharp Aquos... • Answered on Oct 16, 2021
Sharp Aquos LC-52D62U Liquid Crystal Display; Power LED blinks at a constant rate. TV does not come on.
This model was known for bad capacitors in the power board, have you tested them and or power supply voltages?
8/20/2021 12:01:51 AM • Sharp Aquos... • Answered on Aug 20, 2021
2answers
How can I fix my Sharp Aquos TV screen that turn red
One way to deal with this issue is to power cycle your Sharp TV. This way you will be able to find out if the light blinking is due to improper bootup and hopefully resolve it. https://downloadnox.onl/ https://vidmate.vet/ https://vlc.onl/
8/17/2021 11:38:19 AM • Sharp Aquos... • Answered on Aug 17, 2021
Where or is the volume button on my Sharp Aquos tv? I ordered a remote but it won't be here till Sat. Thank you for accepting me on here :
What is the model number of that TV. without it, how can one respond? If you wish to get some details; check the sites linked here. https://elektrotricks.blogspot.com/ https://electronicshelponline.blogspot.com/
7/17/2021 11:59:25 AM • Sharp Aquos... • Answered on Jul 17, 2021
My sharp aquos LC-60LE644U works for 10-15 minutes off antenna
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. . Pull up older posts. http://electronicshelponline.blogspot.com/ . https://elektrotricks.blogspot.com/ http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site by type in the brand name of your TV, at its search box at the right column. View the sites by desktop computer or by Webview by mobile. Mobile view has no search box.
7/11/2021 1:34:53 PM • Sharp Aquos... • Answered on Jul 11, 2021
2answers
I have a Sharp Aquos LCD TV Model LC-32BX6M , when I try to connect a new generation Android TV Box HDMI Out to TV's HDMI input the Android Logo appears and after sometime the screen goes blank t
im not sure but could it be a comparability issue with the device and the wake up signal from the device to the tv? android systems use a Linux based file system, so the problem may be in the tv's input settings. hdmi input from the device to the tv. and then go to tv input mode and see if putting the device in another hdmi port doesn't work.
12/30/2019 1:23:58 AM • Sharp Aquos... • Answered on Dec 30, 2019
What is factory reset code for LC46LE700E
11/17/2019 3:07:14 AM • Sharp Aquos... • Answered on Nov 17, 2019
Sharp Aquos LC-20B6U/LC-20B6E 20 in. HDTV-Ready LCD Television Logo
Popular Tags
7 questions posted
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
Aquos Sharp
  • Aquos Sharp
Most Popular Question
aquos lc 20b6e fails turn sometimes
  • Televison & Video
