Question about Sharp Aquos Televison & Video
Scanned Channels not saving on my Sharp AQUOS 32 LE185M LED TV.
I have to rescan my TV channels EVERY TIME I turn the TV off. It's not saving the channels I got from autoscan.
    Top Expert:
  • Sharp Master
  • 76,823 Answers
Https://elektrotanya.com/cgi-bin/download2.cgi?dk=wgzgtxz9xfakb6w5s2gbjalr7l6hmh579r0th7lfiongeyjc&fid=105643&file=sharp_aquos_lc32_40_46_52le700un.pdf
Should be the faulty memory IC. Download its service manual by the above link, and refer it.
If you wish to get some details; check the sites linked here.
https://elektrotricks.blogspot.com/
https://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault. Search the site by type in the Brand Name of your set, in its search bar at the right side column, and press enter. See it in by Webview with mobile or by desktop. Mobile View has no search box. Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
Posted on Oct 16, 2021
Picture blacks, tv needs to be turned to bring picture back. wii games do not go black
This is caused by your QAM decoder on hi def Sharp sets. You need to rescan for channels, turn off your TV then turn it back on to set to save the channels.The problem lies in the Tuner board and some Hi-Def signals can change frequency slightly due to improperly shielded cables etc. Verify that all of your cables, especially the Cable TV wire are firmly seated on your set. An improperly grounded cable television wire can wreak all kinds of havoc on reception.
Analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
1helpful
Sharp Aquos LC 32G4U not receiving any channels-
Most locations are real hard to get local stations using indoor antennas. If you are in a location where you do not have cable, I would try either a outside antenna on the roof or go with Direct TV Dish / Dish Network system.
I hope this helps,
Skyassoc
I just purchased a used Sharp Aquos 32 LCD model # LC-C3234U without the remote. I have Direct TV and the television needs to be on channel 3. With the buttons on the television the closest I can get is...
Try encompassparts.com and see if they have the original remote. The channels you are getting are digital channels. You are going to have to get it back to analog channels.
32 inch Sharp Aquos is less than a year old... I changed that channel and the picture was green or gray... i changed it again and got a normal picture once but now all channels are looking blank with a...
Contact Sharp to locate the nearest authorized Sharp servicer. Sharp Aquos servicers have to give Aquos TV top priority. Sharp provides very good and fast serice on these sets.
Can't get all my cable channels
what cable company do you have because you should have a cable box because only a cable box can scramble the frequency so you can get the channel you subscribe for
Sharp Aquos LC-52D64U LCD-52 wdscrn tht won't scan in digital...
Seeing that you have a superior brand and not getting channels is a bummer. It may have to do with the setting, make sure you're set to cable rather antenna and then do a rescan. Btw, often times channels from an over the antenna is much clearer than from cable because cable tv has to compress the signal. If you're high in the air like the top floor of a building a cheap $10 will pull in great free digital channels. It helps to experiment and read the troubleshooting guide in your manual.
Televison & Video Logo
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
