Question about Sharp Aquos Televison & Video
My sharp aquos LC-60LE644U works for 10-15 minutes off antenna
After that time picture starts pixelating the goes blank. If I unplug set. Turn on again after 10 minutes. It will work again for 10-15 minutes. It only dose this on tv mode for over the air channels. Set works fine on my cable tv mode.
Posted by Dan Benning on
    Top Expert:
  • Sharp Master
  • 76,823 Answers
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. . Pull up older posts. http://electronicshelponline.blogspot.com/ .
https://elektrotricks.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site by type in the brand name of your TV, at its search box at the right column. View the sites by desktop computer or by Webview by mobile. Mobile view has no search box.
Posted on Jul 11, 2021
1helpful
3answers
My 32-inch lcd tv from sharp has no picture but audio works fine. No picture ever comes up, not even the "please wait" message. Whats going on?
My 3 year old Sharp LC-40C32U would start up fine but within a minute would go dark (audio continued fine). For a while I could turn the set off and on again and it would be fine, but over time this became less effective. My solution, which has worked for a week now, was to a) unplug the set's power cord; b) after 3 minutes plug it back in and turn the set on; c) on the remote hit MENU and slide over to SETUP (3 clicks to the right if the screen is dark) and one up to RESET; d) hit ENTER and follow the prompts. This puts the set in it's factory configuration so you will have to rescan for channels. Worked for me.
2helpful
2answers
Picture goes out right after turning on, have to
4helpful
2answers
Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
2helpful
Sharp Aquos LC-32D41U pictures problem
I have had exactly the same problem. Sounds daft but by not using the remote, and only using the power on/off switch on the TV itself, it is working perfectly...no idea why
Use the remore for changing programmes etc but not for on/off
Try it anyway because I know how annoying this is
Sharp Aquos LC-32D4OU
Comment by Guest, posted on Oct 25, 2008My Aquos has the same problem. I'm not sure how I discovered this, but when I lean the TV forward and hit the power button it will turn on every time. If the screen blacks out and I don't lean it forward when I hit the power button, the screen will just remain blank. It is very weird, but at least repeatable.
- Thank you, Guest. That did it. It definitely seems to be a problem with the TV. Tilting it and hitting the power button helped me get the video back.
Sharp aquos 32'' LCD
Dead pixels are a fact of life on these newer flat panel TV's I dont believe you can fix them. They will be "on" on a completely black picture.
Sharp Aquos LC-32D40U-picture goes off at random times
The bad news,your set needs a new inverter board installed.With persistence to sharp,you might be able to get them to pay for the parts.
Televison & Video Logo
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
