Question about Sharp Aquos Televison & Video
Sharp Aquos LC-52D62U Liquid Crystal Display; Power LED blinks at a constant rate. TV does not come on.
Unplugging power, holding down POWER to drain residual power, pressing VOL DOWN & INPUT while re-plugging power turns POWER LED on steady. At this point TV can be turned off with remote or TV power switch. Turning TV back on lights POWER LED and after about 6 seconds there is an audible click and LED starts blinking again. No HDMI or other inputs are connected
Posted by Donald Rothfuss on
Larry
  • Sharp Master
  • 3,895 Answers
This model was known for bad capacitors in the power board, have you tested them and or power supply voltages?
Posted on Aug 20, 2021
Sharp LC-46LE832U TV
Yes, it does exist!
Support Details LC-46LE832U - Sharp Electronics
www.sharpusa.com > Support
Home > Support > LC-46LE832U. LC-46LE832U AQUOS QUATTRON LED LCD TV ... Have a basic question about your Sharp product? Get started with the ...
LC-40LE832U ' LC-46LE832U ' LC-52LE832U ' LC ...
files.sharpusa.com > ForHome > LCDTVs > Manuals
PDF Consult the dealer or an experienced radio/TV technician for help. DECLARATION OF CONFORMITY: SHARP LIQUID CRYSTAL TELEVISION, MODEL LC- ...
AQUOS LC-46LE832U LED-LCD TV-LC46LE832U ' Eckley ...
www.eckleysappliance.com > Sharp-Electronics-LC46L...
On the LC-46LE832U, this technology is enhanced further with Quad Pixel Plus, which produces smoother lines by enabling the individual control of all 8-million ...
Sharp LC-46LE832U Manuals ' ManualsLib
www.manualslib.com > ... > Sharp Manuals > LCD TV
Sharp LC-46LE832U Pdf User Manuals. View online or download Sharp LC-46LE832U Operation Manual, Connection ... LIQUID CRYSTAL TELEVISION.
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Sharp lc-52d62u with sound and no picture. OPC and power lights blinking.
Sounds like lamp problem. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sharp aquos will not turn on
The Power controll board is likely bad.
Luquid crystal television set - 125-240 AC
You have basically 2 options available to you:
1) Contact Sharp at the address you listed and they will instuct you on what you need.
2) Purchase a power conversion transformer. This will convert the 240AC to 110 AC and you can use the standard 110 AC cord.
Dan
8helpful
Red Blinking Power Light Sharp Aquos
What do three blinks of the power light mean on my Sharp Aquos LC-C5262U? I cannot power up my display.
32helpful
4answers
Sharp aquos
you can try resetting the tv by
1. unplugging it
2. pressing channel down and volume up buttons at the same time while plugging tv back in
3. if you here a click, the tv has been reset
7helpful
No POWER
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
Televison & Video Logo
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
