20 Most Recent Samsung TL110 Digital Camera Questions & Answers
Can not download pictures to computer
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
9/10/2012 6:09:45 PM • Samsung TL110... • Answered on Sep 10, 2012
Samsung TL110 Digital Camera Has A White Screen I
Since you are able to see the menu items and stuff this is not an LCD screen problem , as you have already figured out the hardway. I have seen this problem appear either due to a faulty battery or a malfunctioning CCD-image sensor. In both cases (LCD or CCD) this isn't a job that you could solve yourself; this wrong include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card. I suggest check THIS LINK for additional details in this previous solutions for an Defective CCD (Charge Coupled Device) and next contact your Sony service. I strongly suggest (taking into consideration the age of your camera) to evaluate the cost of repair versus the cost of a new camera with similar features, before making a final desicion.Hope this helps.
9/26/2011 1:31:54 PM • Samsung TL110... • Answered on Sep 26, 2011
I can't find a place
Looking at the front of the camera the socket for the USB cord is on the left hand side , near the bottom. You have to prise open the little cover and the socket becomes visible.
To transfer the files to the computer you must have PC Software option is set to On in the
settings menu and the camera must be turned on.
The manual for this camera is available at the following link:
http://downloadcenter.samsung.com/content/EM/201002/20100225150956515/TL110_QSM_SEA_V1.1_100210.pdf
8/23/2011 1:57:42 AM • Samsung TL110... • Answered on Aug 23, 2011
My camera will not shut
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
12/6/2010 5:22:34 AM • Samsung TL110... • Answered on Dec 06, 2010
My digital camera vibrates
Hi! Make sure you didn't accidentally turn off the "Steady Shot" mode. You can change this mode through the ''Menu'' button. If this is not a reason of vibrations, use manual for your device. You can try to find it here
3/7/2014 11:08:24 AM • Samsung TL... • Answered on Mar 07, 2014
2answers
Samsung manual for 2.1 soundbar subwoofer m AH68-02078F
How i connect to my tv
4/16/2024 1:24:29 AM • Samsung Cameras • Answered on Apr 16, 2024
Samsung ES80 Digital Camera. It is not charging and the red light is not flashing.
The battery has probably failed due to lack of use and regular charging Remove the battery and check it with a multimeter. To see the camera on your laptop you would normally need the software and drivers for it. Support link https://www.google.com/search?q=samsung+es80+software+download Battery https://www.google.com/search?q=samsung+es80+battery ..
2/18/2024 8:00:02 PM • Samsung Cameras • Answered on Feb 18, 2024
My Samsung Es90 digital camera's shutter is not working, plus, the batteries are fully charged but when inserted, it only last 2-3 minutes. What can I do to resolve this?
I'm assuming by "shutter" you're referring to the one inside the camera and not the cover blades on the very front of the lens. How old is the battery and do you use the camera a lot? Old batteries can be fully charged but can become weak and not hold that charge when the camera is powered on. The shutter issue could be part of this as the battery might not be strong enough to power the shutter. I think the batteries for these cameras are reasonably cheap so you could invest in a new one to see if that helps. An extra battery is always useful if you use the camera a lot. If this is an old, well used camera part do wear out so if new battery doesn't help you may need to take it to a good repairer as the camera will need to be taken apart to find the problem.
1/19/2024 10:45:50 AM • Samsung Cameras • Answered on Jan 19, 2024
How to record using SAMSUNG DIGITAL CAMERA DV150F.
How to record Video? check out the manual
SMART CAMERA DV150F ' Samsung Support CA
Samsung https://www.samsung.com > ... > Camera > Compact SMART CAMERA DV150F. Solutions & Tips, Download Manual, Contact Us. Samsung Support CA. ..
11/14/2023 6:33:29 PM • Samsung Cameras • Answered on Nov 14, 2023
Samsung vp-d361, can't detach the battery.
The battery has probably swollen, they do when left flat for a long period of time. Brute force is all you can use and hope you don't destroy the fixings.
10/21/2023 12:20:12 PM • Samsung Cameras • Answered on Oct 21, 2023
Samsung Digimax 301 will not turn on only green light flashes
  1. Check battery polarity: Ensure that you have inserted the AA batteries correctly, aligning the positive (+) and negative (-) ends as indicated by the camera's battery compartment. Improper battery placement can prevent the camera from powering on.
  2. Clean battery contacts: Over time, battery contacts can accumulate dirt or corrosion, hindering proper electrical connections. Use a clean, dry cloth or a cotton swab dipped in rubbing alcohol to gently clean the battery contacts inside the camera's battery compartment. Make sure to let the contacts dry before reinserting the batteries.
  3. Replace batteries: Even though you inserted fresh AA batteries, it's possible that they may not have sufficient power to operate the camera. Try using a different set of new batteries or fully charged rechargeable batteries to eliminate the possibility of a power issue.
  4. Reset camera settings: Some cameras have a reset option that restores the default settings, which can help resolve certain issues. Look for a small reset button or a menu option within the camera's settings to perform a reset. Refer to the camera's user manual for specific instructions on how to reset your Samsung Digimax 301 model.
  5. Firmware update: If your camera has an outdated firmware version, it may cause compatibility issues or malfunctions. Check the Samsung website or contact their support to see if there are any firmware updates available for your camera model. Follow the provided instructions to update the firmware if necessary.
6/3/2023 12:48:29 PM • Samsung Cameras • Answered on Jun 03, 2023
Samsung NV3 Camera. No file, what do I do?
This is a very cryptic, non specific, vague question. Google seems to think that you are trying to say in the least amount of words that there are no files on your SD Card?? https://www.google.com/search?q=Samsung+NV3+camera+no+file This usually happens if you are using a modern SD Card that is FAR too big for the camera specs, OR you didn't format the card within the camera. The Maximum capacity you can use is 2GB Your Samsung NV3 Digital Camera is compatible with 2GB Micro SD memory cards. Maximum Memory Capacity: 2GB Cable Type Compatibility: USB Memory Card Compatibility: Micro SD https://www.google.com/search?q=Samsung+NV3+camera+no+file ..
4/12/2023 3:03:53 AM • Samsung Cameras • Answered on Apr 12, 2023
2answers
Samsung SL202 card error I bought an SD card with adapter and camera says "card error".
Question edited for clarity.This is always because people buy modern SD Cards that are far too bit for older cameras. The maximum size for an SD Card is 2GB. Also you must format the card inside the camera.https://www.manualslib.com/manual/145868/Samsung-Sl202.html?page=86&term=SD+card&selected=1#manual..
3/20/2023 10:11:34 PM • Samsung Cameras • Answered on Mar 20, 2023
How do I download the pictures off the Samsung AF zoom 1050 to my computer?
Is this a 'wind up'? This is an old style film camera. You put film in and send it to be developed! Here is the manual https://www.cameramanuals.org/samsung/samsung_af_zoom_1050.pdf ..
3/10/2023 6:41:52 AM • Samsung Cameras • Answered on Mar 10, 2023
I have a compact Samsung camera WB350F. When I switch it on it says it is connecting to the computer although it hasn't been asked to do so and it sticks in this mode until I remove the battery.
There are a few possible reasons why your camera is behaving in this way. One possibility is that the camera's firmware is malfunctioning, which can cause it to get stuck in a loop trying to connect to a computer. Another possibility is that the camera's USB cable or port is damaged, which can also cause this issue. If the problem persists, it would be best to contact Samsung customer service for further assistance. They will be able to diagnose the issue and provide you with a solution.
1/18/2023 10:48:42 AM • Samsung Cameras • Answered on Jan 18, 2023
My Samsung ES25 won't turn on, I tried replacing the batteries with new 2450 MAH batts. But it wont turn on, what should I do?
Maybe this will help; https://www.youtube.com/watch?v=yw3HuN-KGCg
9/29/2022 7:28:07 AM • Samsung Cameras • Answered on Sep 29, 2022
How can I download Samsung camera PL100 software on SD
Hi, Please visit the Samsung website and search for your device's page. There should be a download section there that you can use. Thank you.
9/26/2022 8:31:53 PM • Samsung Cameras • Answered on Sep 26, 2022
Samsung TL110 Digital Camera Logo
10 questions posted
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
TL Samsung
  • TL Samsung
Most Popular Question
not download pictures computer
  • Cameras
