20 Most Recent Samsung TL34HD / NV100HD Digital Camera Questions & Answers
Hi there. Try this.
Turn your computer off. Unplug the camera from the computer.
Restart your computer. Make sure the camera is off and when you have rebooted, connect the usb cable to the computer. Make sure your not using a usb hub.
Turn your camera on and go to my computer. See if it's listed in your drives.
Let me know if this helps with a comment. If it does help, feel free to rate my answer, and thanks for coming to FixYa.
Rob
Samsung TL34HD /... • Answered on Jul 30, 2012
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTERIf your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
Samsung TL34HD /... • Answered on Jul 19, 2012
It still could be the batteries, unfortuneately the only way to find out is replace them.
Samsung TL34HD /... • Answered on Mar 23, 2012
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
Samsung TL34HD /... • Answered on Sep 10, 2011
Consider NOT using a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Samsung TL34HD /... • Answered on Jul 14, 2011
Consider NOT connecting your camera to your computer.
Samsung TL34HD /... • Answered on Apr 27, 2011
You can probably tell that this is a 'standard answer' that I wrote a little while ago, but to be honest with you, it's a 'standard question' that gets asked a lot! I'm pretty sure Samsung cameras like your NV100HD use SD cards, so it applies to you:
Why does my camera say "Card Locked" or "Write Protected"?
The basics. In the same way that the recordings on audio cassettes and VHS tapes could be protected by breaking off the little tab on the back corner, the material on a memory card can be protected against being overwritten. Instead of a tab to break off, write protection is done by a tiny slider on the edge of the card (opposite the cut corner). Before the camera will take pictures, it's necessary that this slider on the card operates a microswitch in the camera, which it will only do if it's NOT in the 'lock' position. The slider actually does nothing inside the card, which is why I don't call it a 'switch' even though it seems like one. Its only purpose is to be detected by the microswitch in the camera's slot, and it's the camera that takes care of the write protection, not the card.
Diagnosis.
Obviously the first thing to do is to check that the slider is NOT in the lock position. If the camera is giving you this error in the unlock position, it means that the slider has failed to operate the microswitch, or that the microswitch itself is faulty, or possibly that there's some file system error with the card. To diganose the problem, it would be really helpful if you could try two or more different memory cards in the camera and see if just one, or all of them exhibit the problem.
If only one memory card exhibits the problem: In this case, it's clearly something to do with the memory card. Is the slider worn, bent or missing? A missing slider will write protect the card in the same way that sliding it to the 'lock' position will. There's another possibility. I've recently discovered that
some cameras which use xD-Picture cards also give this error even though those cards don't even have lock sliders! Furthermore, some users have reported fixing this error by reformatting the card. Therefore, I feel it's also possible that your error may be fixed by reformatting. Before you do this, make sure that you've copied all you want off the card and then use the camera's 'format' function to reformat the card. I advise using the camera for the format function because this guarantees the correct file system. If you use your computer to format it, you may easily get the wrong one. However if you need to do it this way, see which file system is currently in use on the drive before you start. Go to "My Computer" and right click on the drive which is the memory card, and choose "Properties". Examples of filesystems are "FAT" (probably FAT16), "FAT32" and NTFS; to make sure your reformat is successful, ensure you use the same filesystem as before.
If some memory cards work, and others don't, or the same cards sometimes work but only sometimes:
The slider is really tiny, so it's possible that the number of people reporting this error is caused by lack of precision in manufacturing sizes. It must be hard to make a microswitch that can feel such a small thing. Does a better brand of card work? Can you bear to simply stick to the better brands, or the ones that work most reliably? As a remedy of last resort, you could try wrapping a small strip of sticky tape over the slider to increase its thickness, but I think this is a risky solution. There's a risk that the tape will come off in the slot and cause even more problems, or that the tape will be so thick that the card will jam in the slot and you'll have trouble getting it out.
If all of your memory cards behave in the same way: In this case, it's clearly something to do with the camera. It could be that the microswitch is broken, or there's some software error. Although it's less likely, let's cover the software error first; please find the 'system reset' function in your settings menu and use it to clear everything. Any good? If not, try the sticky tape solution in the last paragraph in the hope that it's a size/fit problem with operating the microswitch, but if that fails we're out of options really, beyond a repair of that microswitch.
Samsung TL34HD /... • Answered on Feb 01, 2011
first you have to check the card broken any side if not broken the try to format from setup menu.after that check if still problem then card problem or in side camera pin broken or tilt beacuse wrong way insert card in side.
Samsung TL34HD /... • Answered on Oct 23, 2010
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Samsung TL34HD /... • Answered on May 31, 2010
Location which may have damaged. Please visit service center.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Samsung TL34HD /... • Answered on Feb 01, 2010
Two beeps mean only that there is a problem.
Whenever a fault is detected Samsung cameras prompt with two beeps, there is no error code, and the camera usually must be tested by a technician to find the fault.
All you can do is trying to remove SD card, and replace battery with fresh alkaline ones. Then try to turn on the camera, when you turn it on , if it still does not start, try tapping gently the back of the camera to help lens out, just in case the fault is lens error.
Also try leaving the camera to rest for three or four days in a dry place with no battery. This can help if camera is faulty because of liquid damage.
If that does not work, then the camera must be disassembled and tested, in that case you can get a quote here:Advance Camera.
Regards.
Samsung TL34HD /... • Answered on Jul 26, 2009
Hi! Make sure you didn't accidentally turn off the "Steady Shot" mode. You can change this mode through the ''Menu'' button. If this is not a reason of vibrations, use manual for your device. You can try to find it here
Samsung TL... • Answered on Mar 07, 2014
If the 'hard items' have come into contact with the screen, they may have damaged it. If so, it will need to be replaced, but this can be extremely expensive. Take it to a local repair facility and get their advice - and an estimate of cost. You may need to cut your losses and replace it, unfortunately. Similar cameras appear to be available on Amazon for around $30.
Samsung Cameras • Answered on Feb 18, 2021
Possible Solutions. 1. Charge the battery 2. If still not turning on, try using a little alcohol and wiping the battery terminal(s) on the battery and the battery terminals in the camera. Use a QTip and allow to completely dry before recharging the battery or inserting it into the camera. 2. Replace the battery with new one. 3. On/Off switch may be defective on camera. Charger may be defective. Wire connecting power from charger to wall socket may be improperly connected or loose.
Samsung TL34HD / NV100HD Digital Camera Logo
18 questions posted
Top Samsung Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
TL Samsung
  • TL Samsung
Most Popular Question
drivers nv100hd camera
  • Cameras
