20 Most Recent Samsung TL 105 Digital Camera Questions & Answers
Just connect the usb cable to your printer only hp or cannon photosmart printer will print your pix directly attaching usb cable select the pix and send to the printing options in main printer menue
Samsung TL 105... | Answered on Jun 12, 2014
sounds like a low battery problem. replace the battery
Samsung TL 105... | Answered on Nov 10, 2013
Sorry, there isn't a way. Once the photo was stored as a black-and-white JPEG file, all the color information was discarded.
Samsung TL 105... | Answered on Oct 03, 2013
That sounds like your battery could be dead/not hold a charge. If you've charged your battery already and your camera still won't stay off and turns off right away, it's time to purchase a new battery for your Samsung TL105.
You can purchase replacement batteries quite cheap here:
http://www.amazon.com/Samsung-Digital-Camera-BP70A-Battery/dp/B003OEDQBE
Samsung TL 105... | Answered on Jul 15, 2012
There's a "Copy to Card" command in the playback menu. Follow the instructions in the "Copy to Card" subsection of the "Play" section in the manual (page 85 in my copy). If you need a copy of the manual, you can download one at
http://downloadcenter.samsung.com/content/UM/201003/20100302182652265/TL105_English.pdf
Samsung TL 105... | Answered on Jul 07, 2011
Hi, replace the batteries. Good luck.
Samsung TL 105... | Answered on Jun 29, 2011
Go into the menu and turn off "face detection".
Samsung TL 105... | Answered on Jun 14, 2011
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Samsung TL 105... | Answered on May 03, 2011
Here is a tip that I wrote about how to find the manuals, drivers, downloads andsupport for Digital Cameras.
DigitalCamera Manuals, Drivers, Downloads, and Support How to easilydownload Pictures from Digital Camera
heatman101';
Samsung TL 105... | Answered on Apr 30, 2011
Welcome to FixYa.
There are three reasons why your camera power ceases while in use.
* The Battery is exhausted
- insert a charged battery or recharged the battery
* The camera is turned off automatically
- turn on the camera power again
* Operation has ceased in a low temperature outside of the camera usage temperature range
- make sure the camera and battery warm by placing them in your pocket, etc. and then immediately before shooting,place the battery in the camera and then shoot.
In your case, posible will be the 3rd reason. If you still having the same issue after doing the troubleshooting. I also suggest to removed and re-insert the battery and try to switch it on again.
If this option wont work, you have to contact your service center.
I will be more happy to know if my solution will help you or not on your issues on your camera.
Feel free to reply on this for any question or comments.
Thank you for using FixYa.
Samsung TL 105... | Answered on Apr 06, 2011
Good day,
This tip will explain a few methods on how to try and fix your lens if it is stuck or you get a lens error on your screen.
Please note that all these methods are used at the users own risk and that I can not be held responsible for any damages or losses that occur while trying these methods.
1. If your camera is still under warranty, send your camera to the manufacturer to be replaced or fixed professionally.
2. If your camera is out of warranty try these methods.
  • Make sure your batteries are fully charged.
  • Remove the batteries for 10min. Replace the batteries and see if the problem persists.
  • Try compressed air. This method can be useful if there are any sand or any other object stuck in the lens motors. Use compressed air with a fine tip. Direct the air between the camera body and lens and move in a circular motion around the lens to complete a full rotation.
  • You can also try to tap the padded USB cover firmly on a flat surface like a table. This is sometimes a surprisingly effective method.
  • The last method is to try and force the lens. Turn of your camera and place it on its back on a flat surface. Look at the spacing between the lens and the body and see if the gap is consistent all the way around the lens. If the gap is not even it is likely that the camera fell while the lens was extended. Now VERY GENTLY push down on the lens were the gap is the biggest until you her a "click". This will indicate that the lens is back in place. Try powering back on.
  • If the lens does not extend or it extend and retracts turn of the camera. Hold the camera in your one hand and with the other hand turn the one part of the lens in a circular motion. Rotate both sections of the lens until you hear a "click". This will indicate that the lens popped back in place. Power the camera back on.
  • The last method you can use is to turn the lens while powering on the camera until you hear a "click". Power the camera of and back on to see if it works.
If any of the methods listed above failed to work for your lens problem it would be wise to take it on to a professional to get your camera repaired.
Thanks for taking the time to read my tip and feel free to let me know if it was of any help.
Regards
15073327
Samsung TL 105... | Answered on Mar 02, 2011
Make sure you have fully charged batteries
Samsung TL 105... | Answered on Mar 01, 2011
I will be important to have the estimate on the work with the Samsung service so as to confirm if the work is worth the cost.
It will be important to check the availability of the part prior to deciding the work to be done.
So check this out.
Samsung TL 105... | Answered on Jan 12, 2011
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Samsung TL 105... | Answered on Oct 16, 2010
you can but the cost would outway the camera.
Samsung TL 105... | Answered on Oct 14, 2010
If you've just bought it, take it back to the vendor and request they demonstrate it to your satisfaction.
If they can't because there's a fault, request a replacement or refund under warranty.
Samsung TL 105... | Answered on Sep 13, 2010
Samsung TL 105 Digital Camera Logo
35 questions posted
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
TL Samsung
  • TL Samsung
Most Popular Question
print pics from samsung tl 105 kiosk
  • Cameras
