20 Most Recent Samsung TL240 Digital Camera Questions & Answers
In the shooting mode, select the lightning bolt icon to bring up the flash menu. For more details, see the "Shooting in the dark" section of the manual (page 43 in my copy). If you need a manual you may download a copy here.
Samsung TL240... | Answered on Jan 16, 2013
In the shooting mode, select the lightning bolt icon to bring up the flash menu. For full details, see the "Shooting in the dark" section of the manual (page 43 in my copy). If you need a manual you may download a copy here.
that is a problem for the tecs at samsung, you will need to send it in for repair.
Samsung TL240... | Answered on Aug 29, 2011
Here is a tip that I wrote about How toget a Digital Camera Lens to work again
Steps toRepair a Digital Camera Lens
heatman101
Samsung TL240... | Answered on Jul 06, 2011
Sound like a problem with the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional. Look at the lens, and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down). Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
If your camera is still under warranty and has definitely not been subject to miss use then contact the Samsung service to find out about a free repair (but as your camera has been dropped this will not apply). If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
You can also have a look at THIS link.
Hope helps.
Samsung TL240... | Answered on Jul 02, 2011
I am having the same problem. Just called Samsung tech support and they say it requires service, so you'll have to send your camera to them to get fixed.
This camera is less than a year old. Not a good sign. I took a chance buying a Samsung camera. Well, I don't think I'll be buying another one.
Samsung TL240... | Answered on Jul 01, 2011
<div><br /></div> <div>remove the battery and memory card. blow out any dust. put back the battery in and turn it on without the memory card. see if you can take pictures, if so then its your memory card. Check the link below. </div> <div><br /></div> <div>http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?SITE_ID=1&amp;PG_ID=0&amp;AT_ID=264556&amp;PROD_SUB_ID=0&amp;PROD_ID=1008&amp;EMAIL_ID=</div>
Samsung TL240... | Answered on Mar 11, 2011
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?SITE_ID=1&PG_ID=0&AT_ID=264556&PROD_SUB_ID=0&PROD_ID=1008&EMAIL_ID=
From your description, it is most likely that the camera memory is full or you are using a very big memory card on it.
It is just like a computer, you see, on a computer, the more items you load onto it, the slower and less responsive it becomes to whatever actions you intend for it to carry out. In the same way, the more pictures you take or items you load on the memory of the device, it is prone to respond to actions or commands in a slower manner.
The most effective remedy for this problem is for you to copy majority of the items that have been stored onto it to a computer and free up some space on the memory of the camera.
This will help it in the sense that there would be less data to process and then it would be able to respond actively to commands.
On the other hand, it might not be the physical and visible files that are slowing it down. In other words, it is not always likely that the pictures on it are responsible for this defect. It might be due to the fact that repeated use have caused it to pile up some system files and this is choking up the memory.
In this case, the only solution is to do a complete format or reset of the camera.
Hope this was helpful? Please comment for more information and thank you for using fixya.
Samsung TL240... | Answered on Feb 10, 2011
Hello Daniela,
Remove the battery first and try slowly pushing it in.maybe there is no power to back it in.
mastergani
Samsung TL240... | Answered on Dec 04, 2010
I'll turn it on but the lense wont go in and the screen would be pitch black.
The best and fastest way to upload pics to a computer is to use a card reader.eae68df.jpg
Samsung TL240... | Answered on Sep 27, 2010
Samsung TL240... | Answered on Aug 29, 2010
Hi! Make sure you didn't accidentally turn off the "Steady Shot" mode. You can change this mode through the ''Menu'' button. If this is not a reason of vibrations, use manual for your device. You can try to find it here
Samsung TL... | Answered on Mar 07, 2014
I presume you have re-charged or replaced the batteries.
Samsung Cameras | Answered on Jan 11, 2020
Have you considered consulting the relevant page of the manual which would have been supplied with the camera when you purchased it ?
Samsung Cameras | Answered on Jan 01, 2020
Samsung TL240 Digital Camera Logo
18 questions posted
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
TL Samsung
  • TL Samsung
Most Popular Question
turn off flash
  • Cameras
